Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers
Old 04-24-2017, 06:40 PM
lowercreekgamecalls lowercreekgamecalls is offline
Default Touch pad
Today while setting my bit z axis I hit the "z zero" button on wincnc. The bit went down and touched the touch pad like it is suppose to do. When it lifted off i noticed it left a small dimple in the touch pad. Is there a way to adjust the down pressure or is this normal. I was using 90 degree v bit.
John Hood
Old 04-24-2017, 07:21 PM
Bruce Page Bruce Page is offline
You can slow the Z feed rate to minimize the contact but the dimples are normal.
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 04-24-2017, 07:28 PM
Ok just wanted to make sure before I messed it up.
John Hood
Old 04-25-2017, 01:14 PM
John, when I first started using my machine I used the touch top because it was there and I thought that was the best way. I cannot remember the last time I used the touch top or the "shiny thing" as some have called it. If you set your Z zero at the spoilboard than there is less chance of digging into the spoil board. Have a look at this posting from a few years back on the subject.
http://www.camheads.org/showthread.p...light=touchpad
Cheers.
Old 04-25-2017, 02:00 PM
Art Mann Art Mann is offline
There are many instances in which Z zero is best referenced to the top of the workpiece rather than the spoil board.
Art Mann
FTC option
Wincnc
Vectric Vcarve Pro 8.5
Adobe Illustrator
Corel Graphic Suite X7
Sketchup
