Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Friends Of the CAMheads > KRS Keypad
Old 01-26-2016, 09:02 PM
Default KRS Keypad Support
The KRS Keypad is a very effective way to use your cnc machine away from the control computer. It hooks up via USB and has a 15’ lead. This extra reach allows the user to get close to his cnc without dragging along a key board that is more susceptible to dust than the KRS. This unit has 20 buttons that is preset from factory to be used on CAMaster CNC routers. It is ideal for the Stinger line but rigid and functional enough for the Cobra. The fact that it is inexpensive makes it a great add-on at time of purchase. If you already have your cnc this unit can be bought form US Router Tools HERE.
The KRS Keypad is open format and can be customized by the free software that can be downloaded HERE. The Keypad can be used in any program that uses Windows. There are many uses of this Keypad, customers have used them for hot keys in design software titles like Aspire. You can even piggy back them and have 2 keypads with different setups that do not conflict with one another.
This forum is for the support of the keypad from KRS (Kevin Stoops) & US Router Tools (Joey Jarrard). All topics should be focused on this use and support of the Keypad.
www.usroutertools.com
Old 05-05-2017, 10:29 AM
Post KRS Keypad
Can anyone tell me if the KRS keypad can be ordered with the keys in a vertical layout vs horizontal?
Also, if I have a recoil lathe, should I order the 30 key version?
Thanks...the KRS looks to be my next addition to my Stinger.
Old 05-05-2017, 01:49 PM
ktringle ktringle is offline
I think mine came with a label insert for both horizontal and vertical.
Kevin Tringle
Stinger II 4X4 w/1.0Spindle
Graphtec FC5100-75 Plotter/Cutter
AutoCAD 2010-Flexi-Sign-V-Carve Pro
Old 05-05-2017, 02:05 PM
KickIt KickIt is offline
The keypad does not care if you hold it horizontal or vertical. The thing you have to keep in mind is that X and Y buttons may need to be swapped depending on how you hold it. They come default as vertical.
20 vs 30 button:
The 30 is the Aluminum version only, 20 is both Nylon or Aluminum.
There is a new insert maker for the 30 since it is a little narrower for the buttons.
The buttons can be programmed for any command you want to program in it. The new keypads supporting 63 keystrokes per button. So for rotary all you need to do is assign the A-left and A-right where you want.
Here is a link to the keypad types and more videos on my page. Each is a couple minuets long.
US Router tools is where you get them.
Kevin
Kevin Stoops
Cobra's 508 ATC
Recoil, vacuum hold down.
Aspire 9, Photo w/Cut-3d, CPP
30W Fiber Laser
TDS Control Keypads - Inventor of the TDS/KRS Keypads
www.krscorporation.com for keypad support home
YouTube Videos
Old 05-05-2017, 04:50 PM
Kevin, any word on Bluetooth versions of the 30-button keypad?
Old 05-05-2017, 04:55 PM
Post
20 vs 30 button:
Kevin
Kevin,
Thanks so much for quick response. I kind of assumed that position (vertical vs horizontal) was a personal preference, but I was not sure if there were different keycovers that needed to be ordered for my preference...or does the program allow you to print your own keypad buttons labels? Sorry to be so dense....
Old 05-05-2017, 07:42 PM
Kevin has on his site i do believe the image to download and change to your needs. you can then print out your custom button setup. i would suggest you having it laminated so it will stand up to some use as well as make it easy to slide into the unit, it can be a tight fit and just a piece of paper would not fair to well.
hope this helps
Old 05-06-2017, 07:13 PM
Post
Thanks, Joey & Kevin. Getting my order ready to place. Cant wait!
Old 05-08-2017, 11:58 AM
no problem
Old 05-11-2017, 12:25 PM
The keypad has been in testing for another vertical market, all seems good. It has not been in the CNC arena yet. Not what I want, but we are working with MicroSoft "new" method of low power Bluetooth communication. It is not as easy as sticking a chip on the current product for BLE. We could but I want the best of the best. It is planned to be both 20 and 30 button in Aluminum.
Microsoft has changed the way they talk and allow you to talk and discontinued the .NET so we are using the new method. This all has to do with the end user being able to customize the keypad only. The keypad side of the project is complete.
In the end this has take a lot longer than I wanted but the product will be very stable, customizable, and will talk to almost everything that is BLE.
Kevin Stoops
Cobra's 508 ATC
30W Fiber Laser
YouTube Videos
