Old 01-20-2010, 07:10 PM
Default aluminum
feeds and sppeds
http://www.youtube.com/watch?v=W-Gk_...eature=related
Old 03-30-2010, 07:41 PM
Default grades
http://www.aircraftspruce.com/catalo...s/aluminfo.php
Old 06-16-2010, 06:59 AM
Aluminum is not as bad to cut as one may think. We use 6061 aircraft grade aluminum for the CAMaster machines. We also use a spray mister while we cut. We try to get a fine consistent mist. This not only keeps the bit cool but by being a fine mist and not soaking the site the chips are removed away from the tool path. If we over do it on the spray then the chips are a bit heavy and tend to clump up. This can make the hot chips join together get stuck in the grove cut out by the prevous tool paths and can snap a bit fast.
The fact is that cutting aluminum and other non ferrous metals can bring in jobs for you in this down economy.
Happy cutting!
www.usroutertools.com
Old 06-21-2010, 04:42 AM
jbarber
Guest
Posts: n/a
Joey,
Since you're bringing it up, a couple of questions:
(1) Do any of the machines in the MC or Cobra class have an extra relay output to start/stop a mister pump/compressor or air valve? I'm shopping for a new medium-format machine... (hint) ;-)
(2) What do you use for a spoilboard when cutting aluminum? I like to use MDF for "dry" jobs, but haven't found anything I really like for cutting aluminum (with a mister) yet.
--jim
Happy cutting!
Last edited by jbarber; 06-21-2010 at 04:51 AM. Reason: Changed "pump" to "compressor" for clarity
Old 06-21-2010, 08:06 AM
1. At the time of ordering just let me know what you need. With WinCNC we have plenty inputs and outputs. All we need to do is add a relay and a signal wire. Depending on what mister you have our buy there are relays already in place and if the amp and voltage are within limits then all hard ware is in place from the get go.
2. at the shop we use mdf and skim or surface it every day. we also have some aluminum plate we use. This al depends on how much aluminum you plan to cut.
Old 09-01-2010, 05:05 PM
turnerwinfield turnerwinfield is offline
Default Milling brass
Hello everyone,
I'm a woodworker that has just ordered a Stinger. I use Aspire to design inlays and carvings for my boxes (turnerwinfield.com).
I was wondering if it is possible to use a router speed control box to slow down the 2.5 Porter Cable router to speeds that can be used to mill small brass bar stock with a milling bit?
Bill
Old 09-01-2010, 08:30 PM
welcome aboard!!
the pc892 will slow to 10000 rpm
i have no experience with brass or whether this is slow enough
http://www.deltaportercable.com/Prod...roductID=11089
Old 09-02-2010, 08:05 AM
Bill I have never cut any brass, but we do use o-flute up-cuts to mill aluminum up to 1" thick. My RPM for this is 16000 with a feed rate between 50 - 150 IPM depending on the diameter of the bit. My cut depth is 0.100" And will do this all day long. I would think that the brass is softer than the 6061 Aluminum we cut so I would start with these parameters and bump up until you get the result you need.
Old 03-02-2011, 08:52 PM
Brigantia Brigantia is offline
Stinger Owner
Default Cut aluminium
Can we cut aluminium with stinger 2? (2.27HP router)
I don't know if i should buy the stinger 2 or the cobra 408?
What's your opinion on it?
Thanks you
I am sorry if my English is not good.
Richard
Old 03-02-2011, 09:44 PM
Richard your english is great.
You can cut aluminum with the stinger but I would not do it as a production run. The Cobra is more solid and will be able to keep up with the stress of a lot of aluminum cutting. There are more and larger bearings on the Cobra as well as larger and more powerful drive motors and spindles to handle the load.
Welcome to CAMheads.
