Old 08-28-2017, 07:13 AM
TimPa TimPa is offline
Default table configurations
trying to decide which table to purchase, mdf, slotted, or vacuum.
we will not be doing sheet goods often if at all. mostly wooden projects. I read that vacuum is the way to go for production work. but then is there a spoil board? is it on top of the vac table.
a little confused on this. like the idea of vac, but not if I am covering it up???
thanks in advance....
Old 08-28-2017, 07:35 AM
You might want to consider using vacuum pods, which will give more holding power. A system where they are easily moved around would be ideal.
You'll probably need to make them yourself, though.
A "normal" vacuum system pulls through the MDF spoilboard, but a system like that probably won't have enough vacuum for hardwood parts, unless you have a really good pump, like a $10k Becker.
Old 08-28-2017, 09:38 AM
Smile Fwiw
Tim, one of the issues with a vacuum table that I did not anticipate was noise. I have the Storm and standing next to it is ~90 db which in conjunction with my 3HP DC was too much. The vacuum is a high pitched noise which is worse vice my DC which is lower pitched. I mounted it outside and ran PVC inside to the machine. After a year of use I still feel I made the best decision with vacuum. I don't have to worry about hold downs getting in the way and/or damaging expensive bits. I have done small parts down to ~6 x 6 inches with no movement. My test is to push as hard as I can against the wood and if it doesn't move than it is good. My machine is small 25 x 36 inch bed so easy to fill the gaps. Those with large machines I think mostly use vacuum but they do sheets.
Ultra Light Density Board made by Trupan is the best for a spoilboard which is what most of us use. As you already know large pieces are ideal but with smaller pieces you need a lot of scrap wood to surround it. Not a problem for me since I make furniture mostly and I have plenty of left overs. Of course you could use the spoilboard to screw your pieces down, double sided tape or plastic nails. The spoilboard is sacrificial There are many ways to skin the cat and as in most problems "it depends". There are no perfect solutions but for me the vacuum works best. I am sure others on here will respond with their experiences but that's my two cents.
Old 08-28-2017, 11:30 AM
tmouse tmouse is offline
If you use pods you can use a smaller Gast pump that is quieter also think about a Fein Vac as a source they are a lot quieter then the black boxes I run 2 and you can hold a conversation next to them
Old 09-05-2017, 11:58 AM
newby questions:
how do you typically route the vacuum from the table to the pods?
what is the best way to have both vacuum table and clamp capability?
Old 09-06-2017, 07:54 AM
Pods would normally be connected directly to the pump, or through a manifold.
Old 09-06-2017, 09:52 AM
Tim,
What is the range of sizes you plan to cut? I work in solid wood too (never use sheet goods) and have a vacuum table that works very well for me. The biggest board it will accommodate is about 8" wide x 22" long. This suits all my needs. Of course you can scale that up, but the bigger you go, the more likely you are to have issues with leaks. The thread below shows some pictures of my table. You can see some of the strips of gasket that make it air tight. If this size will work for you, I will be happy to help. My pump is a Gast 3040 V-115A. It is rated 25 CFM, and 20 inHg. I have the pump upstairs and connected with 3/4" PVC.
http://www.camheads.org/showthread.php?t=7084
If you feel like taking a road trip, come on down.
Charlie
Old 09-06-2017, 10:54 AM
thanks for the info Charlie, and the invite - very gracious. I am in the "all inputs being absorbed" mode, trying to learn as much as possible.
we have so many projects in mind. is that the standard camaster vacuum table?
Old 09-06-2017, 10:57 AM
No, the standard table from CAMaster covers the entire table. This is a small vacuum fixture I made from two sheets of corian glued together.
Old 09-06-2017, 10:20 PM
Here is a link of what I did for my table. I use a piece of 1/2 inch mdf as a spoilboard and put my piece on top of that. My little joewoodworker pump is pulling about 20hg and the piece is stuck like glue.
http://www.camheads.org/showthread.php?t=8540
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
Vectric VCarve Pro 9.0
www.cool-signs.com
