Old 02-14-2017, 09:13 AM
henryz henryz is offline
Default Machine not cutting with short end mill
Hello, I ran in to an issue yesterday, machine cuts fine with longer end mill but when I switch to a shorter bit it doesn't cut and screen displays exceeds Z limit? I'm wondering how I can resolve this.
Thanks in advance
Henry Z
Old 02-14-2017, 09:53 AM
Henry...
You don't say, but I assume you are getting a "Low Z boundary limit" error message.
You must have performed the "Measure Tool" routine with the longer tool and not with the shorter one. Use the measure tool routine with the new tool. After that do the touch top routine, if needed.
Old 02-14-2017, 01:29 PM
Hi Gary this makes sense, so in other woods measure top of spoiler board and then measure top, all I've been doing is measuring top, but usually with long end mill yesterday I popped in a shorter one but it had happened before and that's why I asked here.
Thanks for your help
Henry Z
Old 02-14-2017, 01:44 PM
Henry...
Have you used the "Measure Tool" button? (Shows blue box next to Z)
If you are using the measure tool routine, then you must measure each tool, and then touch top with that tool
Old 02-14-2017, 03:02 PM
Gary, no I haven't but I should be able to figure it out from here.
Henry
Old 02-14-2017, 09:08 PM
Henry
Sometimes in Vcarve I put in .75 for the thickness of the wood. When I plane and sand the wood for the project it sometimes is a bit thinner, say .72 which I forget to change in the Vcarve program. After "touching top" I sometimes run into the exceeded low z issue.
Just my 2 cents if you are cutting this way.
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
Vectric VCarve Pro 9.0
www.cool-signs.com
Old 02-15-2017, 10:56 AM
Hi Bob, that hasn't been the case I'm always changing bits but I noticed it happens when I try using a short bit, and I have been going around and using the long ones until now.
Henry Z
Old 02-15-2017, 03:16 PM
If you want to avoid cutting into the table the "measure tool" button is your friend. Use it every time you change bits. Do it before the "touch top". I know this is the same as what Gary mentioned. Having the reason of saving a hole in your table top might help you remember. Or, just cut the hole, then you will have a visual reminder right in front of you....
