Old 05-29-2017, 11:22 PM
Adam1 Adam1 is offline
Default 120" panel on 96" machine
I have a stinger lll and I need to make a straight cut the whole length of a 10ft panel. Is this possible? Can I make an 8ft cut and slide the panel down, reposition, and finish the cut? I guess my question is can it be done accurately?
Old 05-30-2017, 01:59 AM
Vectric toolpath tiling does this.
Old 05-30-2017, 12:27 PM
I've used the tilling process on some molding and it did a great job.
I'm guessing if your cutting a straight cut you could setup a straight edge on your machine and a good X,Y location and just cut it and move it down and cut the remainder.
Even if you use the tilling feature you need to have the ability to move the pieces down and keep them straight and use the same X,Y location as a starting point.
Mark
MC4848 (mini Cobra) 48 by 48
Aspire 8.0
Old 05-30-2017, 01:26 PM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
The tiling feature is great,,you just need to make sure you have everything lined up and register well.
I recently ran some 10' lengths on my 8' bed with no issues.
Michael
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com/catalog-book/
mm@mezalick.com
Old 05-30-2017, 04:07 PM
Brian O Brian O is offline
How long did it take to run one part 8'
Brian O
stinger III x3
vcarve pro
Old 05-30-2017, 07:18 PM
Awesome thanks guys
Old 05-30-2017, 08:30 PM
I'll need to check tomorrow.
~M
Michael Mezalick
Cobra, WINCNC
3-D Modeling
mm@mezalick.com
