Old 06-20-2017, 10:15 PM
Frank,
Thanks for all your time and work and especially for sharing.
Old 06-21-2017, 07:42 PM
UglySign UglySign is offline
Originally Posted by Bruce Page View Post
There are a ton of nodes in that model.
Hah... ya think there was enough in there?
Seemed like over 200k maybe.
Took a little bit for cleanup.
Got it down to 17k abouts. So it seems clean now.
Why no .AI / .EPS file uploads?
Would a high node count have an effect in cutting?
Anyways, im sure you can use PDFs, no?
2 different, one is inverted.
Old 06-22-2017, 01:26 PM
Signpronfl Signpronfl is offline
High node count kills machining times...reduce that and your time should drop a good bit.
Your run time does not seem too high for such a detailed carving. I generally use 1hr per sqft as a rules for 3D and very detailed carvings. You seem to be near the range. I am sure acceleration value tweaking could make it faster but I only see that as an option if you plan on running this same type of work all the time.
You have been given very good advice so far.
Douglas Hancock
Sign Pro of North Florida, Inc.
https://www.facebook.com/SignProFlorida
Stinger 4'x8'
1.7 KW HSD Spindle
Vectric VCarve Pro
Adobe CS4
