Old 03-22-2011, 02:35 PM
jkindelspire jkindelspire is offline
Default Logitech F310 controller
We just hooked up our new pendant controller for our Cobra. We're using a Logitech F310 game controller to control the CNC without having to be tied to the keyboard. It's not a wireless controller, but with a 6' cord and a 3' extension it gets us close enough to the action. For less than $25 at Amazon, it's definitely worth it.
Our button setup is as follows:
Left joystick up/down = Y axis move
Left joystick left/right = X axis move
Left joystick depress = set XY to zero
Right joystick up/down = Z axis move
Right joystick left/right = A axis move
Right joystick depress = set Z to zero
A button = Enter
B button = Esc
X button = run MACRO_PARK.MAC
Y button = Space
Back button = run MACRO_TOUCHTOP.MAC
Start button = run MACRO_MEASURE_TOOL_1.MAC
LT button = medium transit
LB button = fast transit
RT button = .01" increments
RB button = .1" increments
This gives us a total of 16 programmable inputs that we can customize as we see fit. For now, this seems to be a good number of actions we want to carry out close to the machine during setup. It's definitely advantageous to have a compact control device that allows us to control the CNC while at the workpiece, not at the computer. Also, using the game controller seems to be more intuitive than the keyboard controls. If you've been on the fence about picking up a game controller to use to control your CNC, I'd say do it.
-Justin
Old 03-22-2011, 03:55 PM
Justin the first time I did this I had to write my name in the spoil board just to see if I could. I wish I had took a picture. It is the big kid equivalent to writing in the snow.
www.usroutertools.com
Old 03-22-2011, 04:01 PM
tonywish tonywish is offline
CAMaster Cobra Owner
Default Controller
Is it as simple as just plugging it into the USB port or is it more complicated. Also is a wireless one available??
Old 03-22-2011, 04:02 PM
Default Controller
Is it as simple as plugging in the cord to the USB port or is it more complex? Also is there a wireless model available.
Tony Wish
Old 03-22-2011, 04:46 PM
Tony Wish
Hi Tony,
Check this out http://www.camheads.org/showthread.p...light=wireless in post #9 and on I explain how I set my up my wireless game pad controller.
Mick
Old 03-22-2011, 07:03 PM
Default game Controller
Hi Mick,
I went to that post but all it had was a picture of the controller.
Tony
Old 03-22-2011, 10:03 PM
Tony,
Go to the second page Mick describes the setup in detail.
Good luck.
Mark
Old 03-23-2011, 01:05 AM
Hi Mick,
Tony
Tony,
With the game controller is also a setup disk, once you load the setup disk onto your CNC computer instead of selecting a game to use your controller you select wincnc.exe you can see this inside the yellow square (attached picture) The whole setup takes about 10 - 15 minutes.
The way I have the Logitech cordless rumble pad 2 setup is as follows:
Left joystick
Left / Right = Left and Right gantry X axis
Up / down = Forward and backward gantry Y axis
Right joystick
Left / Right = none (not set any commands)
Up / down = Router up and down Z axis
Button #1 = Router "On" (This was one of the options I bought when ordering my stinger, CAMaster installed some relays.)
Button #2 = Router "Off" (Same comments as above)
Button #3 = "Enter"
Button #4 = "Space bar / pause"
Button #9 = "Home" X0, Y0
Old 03-23-2011, 09:21 AM
Kevin Case Kevin Case is offline
I ordered one from Amazon with the link supplied so I hope it is that easy to set-up. Thanks.
Old 03-23-2011, 11:23 AM
It is incredibly easy to set up. Windows recognized the game controller immediately. It is necessary to use the software to set up the buttons for WinCNC. It took 15 mins tops for me to get the controller working.
