Old 11-26-2015, 08:52 AM
Default BIG sign Small machine
had to do another sign larger than my table, there was some discussion on how to index (Not tile)
I use locater lines (vectors) which once placed become my vector spilits to run two files after moving the sign. I use the move selection to get it right !
if the sign is 82" from y 0 then I move file -82" at y0
Old 02-21-2017, 03:39 PM
accross26 accross26 is offline
Thats a pretty cool idea. I have done some tiling and always end up a very slight offset at the joint. One that is small enough to usually sand out, but larger enough to be a pain in the rear. I always figure its just my imperfect re-positioning and re-zeroing. Does this method help that and/or easier than tiling?
Adam Crosswhite
accross26@gmail.com
CAMaster Stinger I
WinCNC + VCarve Pro + PhotoVCarve
oversize
