Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Materials we Need !!
Old 09-20-2016, 11:26 AM
WatereeCarpentry WatereeCarpentry is offline
Post LDF Supplier around Sumter, SC
Hi, I'm trying to find a supplier for the LDF I need for my table top.
I haven't been able to find any near Sumter, SC.
Any ideas?
Thanks ahead of time!
Old 09-20-2016, 11:45 AM
Ldf can be obtained from A & M in charlotte, i do not use it i use yellow mdf (not Brown) and with a 20 hp vac it will work fine.
Old 09-20-2016, 12:27 PM
abesau abesau is offline
Interesting, where would one find the yellow MDF? Thx
abesau
Stinger I - SR-23
3.5 HP Milwaukee Router Model 5625-20
Performance Package Pro
Phenolic Table Top
Software - WinCNC
Design Software - CUT2D
Old 09-20-2016, 12:31 PM
Most anywhere, the browner mdf has a lot of adhesive in it, i have found it to not work as well and do not use HDF (High density)
Old 09-21-2016, 05:16 PM
I just went down to the local Home Depot and bought their common MDF as below:
http://www.homedepot.com/p/Medium-De...8112/202089064
I flycut it on both sides and it works fine. My vacuum pulls 9 inches max and with the spoilboard MDF it pulls 7 inches. It will hold anything larger than 2'x2' without any scraps but I usually use them anyway to ensure it doesn't move. Works well. I read that I can fly cut down to 3/8 inch and then get another 3/4 sheet and go to the same and then glue those two together and start over. I am going to try it and see. Cheers.
