Old 09-05-2017, 07:58 AM
Scott, it's "A&S Old Glory Heavy" available from Steve Contreras at Signfonts.com
Old 09-05-2017, 08:27 AM
NorthernMN NorthernMN is offline
Thanks TR, they have some really well done fonts on that site. Now I just need to figure out how you create the outline that really makes your signs pop.
Scott Weinmann
Stinger 1 SR-24
Standard 3.5hp Router
Counter Balance, 2" Gantry Lift
T-Slot Table, Remote Keypad
WinCNC, VCarve Pro 8
Old 09-05-2017, 12:54 PM
Art Mann Art Mann is offline
I don't currently use HDU because I experimented with it and found it to be rather flimsy and subject to mechanical damage. I don't do really fancy signs but I have found that sheet PVC works well if I pay attention to its limitations and it seems more durable. It is also less expensive.
Art Mann
FTC option
Wincnc
Vectric Vcarve Pro 8.5
Adobe Illustrator
Corel Graphic Suite X7
Sketchup
Old 09-06-2017, 07:31 PM
Art, have you tried the higher densities? I know PVC is easier to work with in some respects, but if you want to add a carved applique, especially a handcarved one, well, I think it would be a bitch to carve.
Yes, I know this is a CNC forum, but I see no reason to spend hours modeling something that I can handcarve in a matter of minutes. I feel that one can be far more creative ( dimensionally) with HDU than with PVC.
Cost isn't really an issue for "high-end" signwork. It's not us, the signmakers, who bear the cost of materials ......it's our customers. If $4000 worth of signage can come from a single $600 sheet of HDU, or a $400 sheet of PVC, should that really make any difference? It all depends upon what you plan to do with that sheet ......
Old 09-06-2017, 07:41 PM
Scott .....
I design in Corel & export as a .eps to fetch it into Aspire.
In Corel, I do one or two outside contours, at least .125" thick. I separate them all, then duplicate the outside one and offset it to wherever I'd like the shadow to be & weld the two together. Then, I take the inside outline, & use it to trim the welded one & "poof" ... you have a letter with a "ditch" around it & beyond that, an outline/shadow. All you have to do then is clean up the ragged bottoms of the shadows into a consistent angle ( this is the time-consuming part.)
