Old 08-17-2018, 05:33 AM
Default Wedding Gift
15" in diameter ..... Corafoam U200
I had no idea how to get "crisp" edges on the "C" so I handcarved it. I assumed it would have to be modeled, & although modeling works nicely on organic elements, It seems to "round over" stuff that needs sharp edges.
The handcarving & sanding out of toolmarks took about 20 minutes total.
Old 08-17-2018, 08:55 AM
Super nice looking sign. Not quite sure what you're referring to as crisp edges on the C, but try the "Prism toolpath" in aspire and it should do what you're looking for with the right vbit.
Old 08-17-2018, 09:18 AM
Your usual excellent job, TR. Very nice indeed.
Old 08-17-2018, 09:20 AM
If you use a prismatic toolpath, it will erode the edges of the bar that goes across with the V-bit...
TR - Nice work. For jobs where edge crispness is important, AND you are doing 3D work, you need to jack up the modelling resolution & keep the overall size of the project/workspace small. In other words, don't make the workspace 4x8' if the sign is only 12x12". There is no effect on quality with v-carve, prismatic or other 2D or 2.5D toolpaths...ONLY 3D.
To jack up the res, hold the shift key and keep it down when you create a new model. This will open up 20x and 50x resolution in the drop down. Default max is 7x...which is not enough for many things 3D.
Also be sure to jack up the toolpath simulation quality because the default setting tends to be too coarse/sloppy for visualizing 3D work - and edges appear washed out.
Old 08-17-2018, 09:51 AM
That's a really beautiful commemorative sign, TR! My nephew is getting married soon and I may think about creating something similar for he and his bride...great idea!
Old 08-17-2018, 06:56 PM
Brady said...
This is correct, & the reason why I pulled out the gouges & carving knife.. Plus, I wanted a constant return height, & with a variable stroke width, the angle has to change.
BTW, Brady, thanks for the clarification on 3D "crispness". the last time I did anything 3D on the router, Tim Merrill walked me through it. So, I'm certainly not in practice ....
Old 08-18-2018, 07:40 AM
TR - no sweat. If you need help with the 3D stuff let me know. It's been my focus for almost 20 years...
Old 08-21-2018, 06:12 AM
neal_meyers_jr neal_meyers_jr is offline
CAMaster Cobra Owner
Send a message via Skype™ to neal_meyers_jr
Cool
Where is this setting Brady. I gave a quick look but do not see it. I knew where the X20 X50 setting but not the tool path???
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Aspire 4.0, WinCNC, Rhino, Mastercam, Autocad, Catia.
Old 08-21-2018, 06:45 AM
Neal,
It's under the Toolpaths menu.
Old 08-21-2018, 06:50 AM
Cool
Neal,
Yes, Yes it is......Thank you
Owner with Recoil
Neal Meyers Jr
Guyton Ga
