Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Questions For The Sales Team!
Old 09-25-2017, 03:23 PM
Stormwaltz Stormwaltz is offline
Question Z-Axis Touch Pad Replacement
Hi guys - just curious what the ballpark price is on a replacement Z-Axis touch pad. (Non FTC/ATC - just the aluminum pad on a cord.) PM is fine, Thanks!
Gene "Stormwaltz" Fairchild
Eldritch Arts - Owner/Designer/Engineer
______________________________________________
Software: Windows 7, WinCNC, Vectric Aspire
Stinger II SR44
3.0 kw HSD Spindle w/Speed Control
Closed Loop Stepper System
Gantry Lift
T-slot Top
Old 09-25-2017, 08:02 PM
gachua gachua is offline
What's wrong with your existing touch pad?
Asking b/c if it is the cable that is damaged it's a quick fix. Don't ask me how I know ;)
Glenn Chua
gachua@gmail.com
Morrisville, NC
CAMaster Stinger III
Old 09-25-2017, 10:09 PM
Bruce Page Bruce Page is offline
The touch surface can also be re-machined, and the macro adjusted.
Bruce Page
2013 Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 09-26-2017, 12:22 PM
Brian O Brian O is offline
Default touch pad
Mine changes size .005 from one side (short side) to the other. I just marked a spot that I always use.
Brian O
stinger III x3
vcarve pro
Old 09-26-2017, 02:29 PM
Someone with a CNC machine should mill it flat. ;-)
Mike Davison
Stinger II 4x4, Recoil, spindle, FTC, Aspire, Sketchup
http://www.DavisonWoodworks.com/
Old 09-26-2017, 05:38 PM
HMMM, It should have been flat when I got it. I would really like a pressure switch instead to keep from dinging small end mills and v bits.
Brian O
stinger III x3
vcarve pro
