Old 07-13-2018, 10:30 PM
Doug S Doug S is offline
Default Its alive...
Well, After many long days and nights, and a fairly good chunk of money, my "new to me" Camaster Cobra is alive and running.
I am planning on running mostly sheet goods from Mozaik thru it and have a few orders sitting on the shop floor already from overly eager customers.
I tried to get three phase power but the electrical company wanted 31K to run it 1000 feet to my house. I opted to go with the digital Phase Perfect system to ensure the cleanest power to the unit as I could. I went with a 40HP system to run my old ass 300 gallon compressor, 20 HP Becker pump and the CNC. The Oneida 5 hp industrial is 220 single phase, and loud as hell.
I started milling the old spoiler board as my test and it appears I need to check the tramming on the head as it is leaving a fairly good bump at every step. Yes, I went with the 4" head to make matters worse.
I will do some searching on that but if anyone feels like telling me the way, I will surely listen.
Thanks again to everyone for all the help and the questions have only begun.
2014 Cobra 5x10 ATC, Aspire, Mozaik, 20 hp Becker Vacuum Pump-Central Texas
Old 07-13-2018, 11:42 PM
Looks great! time to let the chips fly!
Old 07-14-2018, 08:30 AM
Pete Cyr Pete Cyr is offline
|________________
An inexpensive tramming tool you can make ....bend a piece of 0.25 steel rod as shown above. Mount in 0.25” collet.
Bends ..the up and down portion can be any length but at least 3” for ease of use. The horizontal length should be around 12”.... the longer the more accurate but I don’t recommend more than 15”
With the rod mounted in your spindle ...adjust the spindle height so the rod is close to the spoil board while manually positioning the rod parallel to the gantry.
Check left and right parallel to the gantry. Using feeler gages or a shim to gage clearance to obtain an equidistant measurement while loosening spindle mounting fasteners to adjust the spindle orientation.
Young can also tram the spindle by positioning the rod perpendicular to the gantry....but you will have to shim the spindle Mount.
You can get a very accurate tram using this process.
You may want use a small piece glass under the rod end initially (3”-4”) to get an average surface height when measuring since you indicated you have ridges.
After tramming...resurface, the check tram again. It if desired.
Pete
Pete Cyr
Aspire, WINCNC
Old 07-14-2018, 09:17 AM
Here's a little bit of the good news and bad news about tramming.
The bent wire method works, the gauge method works, lots of ways to skin that cat.
So, if like me, you do the following:
Surface table with large bit
Use a machined plate (that sits very well on the high spots0
Carefully use a tram gauge (as shown in the pic)
You will almost always have to make a minor adjustment once you put the large surfacing bit back in and surface the table.
Its almost easier to just adjust the spindle based on the results from surfacing
Old 07-14-2018, 12:30 PM
Congrats on getting things up and running!
The solution for the noise is to get an enclosure around your cyclone (and other noise-producing gear like compressors. My cyclone and compressor live in a sound-deadened closet in my shop with a baffled air return to prevent direct transmission of sound. It made a "YUGE" difference, trust me, and was worth the time and effort. The only real nose with my CNC now is the cutter when it's engaging material like wood. (it's "almost" silent when running foam...or at least doesn't interfere with the tunes coming from the shop speakers :) )
Old 09-17-2018, 03:53 PM
John B John B is offline
Gary
I have a tram spindle that will span as much as 6", but no dial indicators...before I go spring for a couple, most that I've seen are touted to "accurate to" .001" Is that what you're using? (sorry, your picture was just blurred enough that I couldn't make out the brand name of the one you showed
Old 09-17-2018, 04:43 PM
Ballistix Ballistix is offline
Originally Posted by John B View Post
Gary
It looks like a Pro Tram from Edge Tech. $99.99 as you see it.
At Shars, you can get 10% off if you sign up for email.
Old 09-17-2018, 06:51 PM
John...
As long as you go to a qualified surface, you can use what you have with feeler gauges
