Old 12-12-2016, 10:45 PM
Default Adding a 2nd vacuum pump
I use a gasketed vacuum fixture and am running a Gast 3040 V115A oiless pump. It is rated at 25 cfm and 20"hg. Usually this pump pulls between 15" and 20" on my parts which is fine for my needs. However, occasionally I have enough leaks that the vacuum drops below 15", and then the hold down can get iffy depending on the size of the parts. I am thinking about adding another pump just like this one so that when the vacuum is low, I can switch on the 2nd pump to overcome the leaks. So, my question is: if my vacuum has dropped to, say, 10"hg, and I turn on another 25 cfm pump, do you think that should be enough to bring the vacuum back up over 15". It seems feasible to me, but I just thought I would throw it out here for your thoughts.
Charlie
Old 12-12-2016, 11:14 PM
Charlie...
You should be able to get a pretty close guess by looking over the flow charts for the two pumps. Look at your existing and see what the flow is when the vac drops to 12-14. Then see what the other one is pulling at that flow.
Make sure you have a check valve between the two pumps.
Old 12-12-2016, 11:29 PM
Thanks Gary, I wouldn't have thought of that. Both pumps will be identical, and the flow chart is below. It looks to me like when the 1st pump drops to 10"hg, it will be moving about 15 cfm. So does that mean that when I turn on the 2nd pump, it will raise the vacuum by 10"? I'm using the bottom line for my rpm.
Old 12-13-2016, 06:57 AM
Charlie...
Due to the fact that dual pumps fight each other a little the factor is around 1.9. So, 15 cfm / 1.9 = 8 (7.89) Looking at the vac for 8 cfm shows ~16.5inHg.. That should get you somewhere near real world numbers.
Old 12-13-2016, 08:47 AM
Charlie, I just bought a cheap one way plumbing valve and put it between the pumps. This way I don't have to worry about opening any valves when I turn the second pump on, or forgetting to close a valve and losing a part when the second pump isn't turned on.
Old 12-13-2016, 09:57 AM
Thanks Gary. I can't say I understand all that, but I know enough to take your word for it. I got a good deal on this pump, so I'm gonna give it a shot. It'll also be nice having a backup just in case.
Russel, I like that idea. I was going to use valves as in the diagram below. Would the check valve simply replace one of these valves, or should it be reconfigured? Is it necessary to increase the size of the pipe where both pumps are running to the fixture? Right now I am using 3/4" pvc.
Old 12-13-2016, 10:02 AM
Would this type of check valve be good enough?
Old 12-13-2016, 10:35 AM
Charlie...
You can replace the ball valves with check valves in your diagram. Just switch pumps on/off as needed.
You will have to try the check valve to see if it holds up to your vac levels
Old 12-13-2016, 10:52 AM
I think 3/4" pipe is plenty. You want the least resistance to airflow possible, so larger diameter is better. BUT, you also want a smaller volume to evacuate so the parts seal quicker. If you are only getting 15cfm airflow with the leakage, 3/4" pipe is probably a good size.
I use 1" PVC for mine, but I have a 60cfm pump that leaks a little more than your set-up (I often drop to 10-12"hg on some of my jigs, but my parts are larger so that still provides plenty of hold down).
Old 12-13-2016, 10:58 PM
Thank you Gary and Russel for your suggestions.
