Old 08-03-2017, 03:12 PM
Default Vacuum table 2.0
So I ditched the Corian vacuum top. I assumed that the Corian was perfectly flat, wrong. It was a thousandth off here and there so it drove me crazy. I decided to replace it with a 48x48 piece of HDPE. It turned out great. I just make small/medium signs mostly Corian now so I just leave an onion skin on them.
File Type: jpg BFF4E71D-CF08-40FC-9532-7EA9C2EBBCFC.jpg (86.0 KB, 158 views)
File Type: jpg E6FCA5AC-F221-40C0-B637-A1698C809183.jpg (88.9 KB, 132 views)
File Type: jpg 1FC4AAA6-0D40-406E-8397-7A41AA3EA0A1.jpg (76.2 KB, 132 views)
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
Vectric VCarve Pro 9.0
www.cool-signs.com
Old 08-03-2017, 03:20 PM
R.L.Schulz R.L.Schulz is offline
Great idea Bob!
- How wide/deep are your channels
- What type/size gasket for seal
Ron
Ron & Tammy Schulz
CAMaster Stinger III SR-48
X3 + 2" Gantry Lift + Extended Gantry
HSD 3.0 KW + Counter Balance
Laser Pointer + Tool Measure Switch
Indexing Recoil Lathe
Hurricane Vacuum System
Vectric Aspire 9/9.5
Cabinet Planner
Old 08-03-2017, 05:20 PM
Originally Posted by R.L.Schulz View Post
Great idea Bob!
Ron
The channels are 1/4 inch wide and .1875 deep. I use a 1/4 inch gasket. I use the Joe Woodworker vacuum set up. There are also 1/4 inch holes in the HDPE that I use 1/4 inch stainless steel pins so I can put the work back in the exact position if I need to do multiple pourings of epoxy. I used a 1/4 ball nose for the channels.
File Type: jpg 56BC5880-4FB9-4B79-8CDB-D514ACBF890A.jpg (95.8 KB, 84 views)
File Type: jpg EABEB55E-2B14-40A7-A6EF-567A7E33ED56.jpg (97.8 KB, 69 views)
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
Old 08-03-2017, 05:22 PM
Great idea Bob!
Ron
Where are you in Cincinnati? I just saw that. Awesome
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
Old 08-03-2017, 05:56 PM
Bob,
We are in Bridgetown/Western Hills.
We need to get together some time, we just camped earlier this season at Cedarbrook, I was going to look you up.
Ron & Tammy Schulz
Cabinet Planner
Old 08-03-2017, 06:41 PM
Bob,
Anytime. I'm literally 1 mile from 71 exit number 32. (St rte 123)
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
Old 08-03-2017, 07:35 PM
Bob, is the HDPE more uniform than the Corian? I was surprised...would have thought the Corian would be dead flat. Go figure!
Old 08-03-2017, 08:16 PM
I was afraid to "plane" the Corian with the machine. I figured that a 48x48 piece of HDPE would work/look better then the 48x30 Corian (and I'm a bit OCD). Haha. I was also reading that there is a bit of movement with the Corian and temperature.
I was also trying to make the squares smaller so I could hold smaller pieces down. These are 1 inch.
I can send you the vetric file if you are interested.
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
Old 08-03-2017, 08:32 PM
Did you plane the hdpe? I would think that would be about the same as the Corian from that aspect. But...I am just "thinking" whereas you are actually doing, so I will learn from your expertise!
I appreciate the offer for the files, but I am doing just fine with the previous ones you sent me...in that "not really flat Corian"! Hah. I may take your advice and shrink my squares down to 1" I currently have them at 1.5"
Oh yeah....the new vac table looks awesome! Maybe you should start selling vac tables along with your beautiful signs.
Old 08-03-2017, 09:20 PM
Yup I planed the HDPE, it looked like the sit on Santa's lap at the food court in the mall in my garage. Had to turn off my dust collector because all the plastic shavings were sticking together like Velcro. It was a disaster, hopefully won't ever have to plane hdpe ever again haha. But now I know it's perfectly flat which makes me smile. Plus I have never worked with it so it was an "on the fly" feeds and speeds guessing game. It's pretty bad when you are googling feeds and speeds in the middle of Mick Martin spoil board wizard. (But it made for an exciting experience).
Also with the hdpe I had more of it to work with being its .75 and the Corian is only .5.
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
