Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The File Swap Meet > Vectric Rotary Files
Old 12-15-2011, 09:09 AM
dschutz dschutz is offline
Default Recoil Post Processor
Hi all,
How do I know if I have a post processor for my recoil?I am currently using "CAMaster_X3_Arcs_inch.pp" for all table top work.
I am also trying to find a tutorial for doing a "touch top" on the recoil.I keep being pushed to 222artisans,leaving me to believe that I am clearly not understanding something or I just don't get the lingo.
Any help would be great.
Thanks again,
Old 12-15-2011, 09:43 AM
Originally Posted by centrotherm View Post
Hi all,
Thanks again,
Doug,
The post processor you need for your recoil is "CAMaster XtoA.pp" I will attach it to this post.
I don't think there is any information on using touch top for your recoil, you could build a Jig and place your touch pad on top of it at the same height as your drive center, must people tend to work off the center line. I have a laser that I install in my collet, I then jog the spindle/router so the laser is on the tip of the drive center is give you the X and Y value. Then measuring the diameter of the drive center, then installing a bit or a piece of 1/4" round stock. Jog the router/spindle to top dead center on you drive center, carefully touch the top of the drive center then record the Z value jog the router/spindle into free space then enter half the diameter (radius) into the command line eg Z-1.25 (enter). Maybe some else has a different method they can post.
Old 12-15-2011, 09:45 AM
also bracket out x and unbracket A,, or i believe you can simply un bracket A
Old 12-15-2011, 09:49 AM
i always leave a bit of material at the base and work all xyz from there
Old 12-15-2011, 10:21 AM
Default Thank you gentlemen
Great,
I am eager for info.This stuff is great and the community sure helps.
Thanks,again,
Old 01-11-2012, 10:40 PM
Is there an 'x to a' post processor that supports the cobra ATC function?
Old 01-12-2012, 12:11 AM
Russell,
I am not to sure about the ATC but I would think it's the same as any other CAMaster machine, they use 2 post processors 1 for flat work XYZ and the other for the recoil.
Old 02-03-2012, 10:18 PM
Does the regular XtoA pp support tool changes with the ATC?
Old 02-04-2012, 08:42 AM
Russell,
I just viewed the post processor I posted in post #2 above and it supports an ATC machine.
