Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The File Swap Meet > Vectric Rotary Files
Old 03-14-2013, 09:01 PM
neal_meyers_jr neal_meyers_jr is offline
CAMaster Cobra Owner
Send a message via Skype™ to neal_meyers_jr
Cool Wraped work
130 Spindles done. Now for the rails........
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Aspire 4.0, WinCNC, Rhino, Mastercam, Autocad, Catia.
Old 03-14-2013, 09:12 PM
BFenn BFenn is offline
Neal,
You have been a busy guy. They turned out well. It will be nice to see the rails, when you complete them.
Brad Fenn
Old 03-14-2013, 09:14 PM
Cool
I will post. Too much work went into using the recoil All Camasters should get them!
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Old 03-14-2013, 09:30 PM
eandico eandico is offline
How long per spindle?
Best,
Nick
www.theeandicompany.com
Old 03-14-2013, 09:35 PM
Cool
90 minutes per roughing. 30 min finishing each one.
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Old 03-14-2013, 09:59 PM
What is the length and max diameter of the spindles? What wood did you use?
90 + 30 = 120 minutes per spindle x 130 = 1560 minutes = 26 hours WOW
Old 03-14-2013, 10:26 PM
Ya missed a zero there Mick! 260hrs
2hrs per is a long time!!!!!!!
Best,
Nick
Old 03-14-2013, 10:45 PM
Your right Nick ..... I ran out of fingers and toes
Old 03-14-2013, 11:32 PM
2 hours each? That's dedication! You need a lathe duplicator. Could make them in less than 10 minutes each with an old fashioned duplicator!!
You could also change your stepper motor for a normal lathe motor, and mount a gouge and a parting tool to the aluminum plate where the spindle is mounted. Then use the Y and Z axis to carve out the shape from above with the gouge and parting tool while the lathe spins (just offset the gouge and parting tool so both can be mounted and used by just changing the x position).
Or mount a mini lathe onto the cobra bed and do the same thing with a gouge and parting tool. Just some thoughts to speed things up!
Old 03-15-2013, 12:02 AM
JohnnyCNC's Avatar
Neal,
I'd like to discuss your feedrates with you. I believe we can cut that WAY down. I could be wrong, but email me your tap file if you will. I'd like to have a look. Also include your wincnc.ini file and your Aspire post processor if you don't mind. It'll probably be tomorrow before I get a chance to look at it, but I will look at it for you.
JohnnyCNC
