Old 12-04-2014, 09:45 AM
aaronwe aaronwe is offline
Default Post Processor for Stinger 2 with FTC for Autodesk Fusion 360?
Hi:
Anyone using Autodesk Fusion 360 with their Stinger 2 with FTC and recoil, or even without recoil, where can I find the post processor?
Thank you!
Aaron Weinstock
www.NePalo.com
Stinger II 4X4
1.7 KW spindle
Recoil-FTC-Laser
WinCNC, Aspire, Rhino, Vectorworks
Old 12-04-2014, 12:10 PM
Originally Posted by aaronwe View Post
Hi:
Thank you!
You need to contact Autodesk Fusion 360 and see if they have a post processor that runs using G-Code.
Old 12-04-2014, 12:30 PM
looks to be good gcode to me call auto desk, they will need some code from you and a pp that works now
http://fusion360.autodesk.com/features
Old 12-04-2014, 01:24 PM
Thank you!will do!
Aaron Weinstock
www.NePalo.com
Stinger II 4X4
1.7 KW spindle
Recoil-FTC-Laser
Old 12-05-2014, 01:54 PM
Here is the Generic camaster post processor for Fusion 360 if anyone is interested
Aaron Weinstock
www.NePalo.com
Stinger II 4X4
1.7 KW spindle
Recoil-FTC-Laser
Old 12-05-2014, 07:23 PM
Terry Williams Terry Williams is offline
Please post your experiences with Fusion 360 and your router when you finally get it going!
Terry
Terry Williams
Cobra 510 with Recoil
Old 08-11-2015, 03:05 PM
_peter_ _peter_ is offline
Default Any results with autodesk post?
Hey Aaron, thanks for uploading the postprocessor. I was wondering, how did it work out for you?
Hartmann Computer Consulting
http://blog.hartmanncomputer.com
Fat Cat Fab Lab
http://fatcatfablab.org
Stinger 1 + spindle upgrade + FTC
Old 12-09-2015, 11:57 AM
rcoren22 rcoren22 is offline
We successfully used this post from Fusion 360 to Camaster Stinger 2.
It was a countour test file in foam using a 1/4" Ball Nose End Mill.
The file ran smoothly, however we did not test for the Fast Tool Change.
Thanks so much for the Post Processor.
Old 01-14-2016, 10:55 AM
steina81 steina81 is offline
Did you use the generic wincnc post processor?
How is the Fusion CAM working? I am about to jump from Vectric.
Allan Steinkuhl
Cut 2D
Cut 3D
Design Cad Max 3d
Old 11-13-2016, 04:26 PM
WhiskeyBlade WhiskeyBlade is offline
Default Fusion!
I currently run Vcarve 8 for my Router. I am teaching myself Fusion and 3D cad to expand my own knowledge and capabilities.
As for the POST for it, have people been having luck?
My main question is.....
Does it work with the Indexing lathe?
Stinger I, FTC & Laser
2.25hp Router
INCRA T-Slot
Vcarve Pro and Photo Vcarve
Wired for Indexing Lathe (Someday)
fusion360, post processor
