Old 03-07-2018, 05:25 PM
bmc0787 bmc0787 is offline
Default dome shape
Hi All
hopefully I can expalin this correctly.
I have Vcarvepro and want to see if I can machine a small dome shape that is about 4 1/5" circumference and peaks at 3/4" in the center. The shape is as though I sliced the very top off a ball. Is it possible to draw and machine this in Vcarve? I am having no luck figuring this out.
thanks
Brian
Old 03-07-2018, 05:44 PM
Brian...
There are domes and dishes included with the clip art. Select one, adjust height to your needs and cut away!
Old 03-07-2018, 05:50 PM
If you click on the modeling tab, you can create a dome of any diameter and specify the height.
Old 03-08-2018, 09:45 AM
You can't create a dome in VCP - only Aspire. You can of course import one from somewhere else or as Gary points out, pull in one of the clipart examples and scale it to suit.
Post the specs you require if you want me to make you a 3D model for import. Use decimals...not sure if you meant 4.20" diameter, circumference or what in your original post...
Old 03-08-2018, 07:38 PM
Oops, I didn't even notice that he was using vcarve. My bad.
Old 03-09-2018, 03:33 PM
thanks guys for all the help.
I took Gary's advice.
I did not realize that I had not downloaded all of the clipart, which I just did.
thanks again,
Brian
