Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers
Old 04-16-2018, 09:40 PM
Rlee1972 Rlee1972 is offline
Originally Posted by EnvisionIT View Post
This is something I never thought of...
I have a PneumaticPlus 3 stage air drying system just after the compressor the specs say it can pass 43 SCFM @ 90 psi...
I have a 5 hp Quincy air compressor that delivers 15 cfm at 90 psi.
Do I need a refrigerated unit or will the above unit suffice?
Forgot one tidbit. I also have and started out with that same 3 stage brand you have listed. I still had moisture showing up on my CAMaster trap until I put the dryer in.
Ron Lee
Blackshear, Ga
2017 CAMaster PT-408
HSD 5HP ATC
6 Tool Rotary Carousel
Aspire 9.0
On order:
Cobra Elite 5 x 10 ATC
"You never learn anything by doing it right."
If that were true, I would be one of the most intelligent people you would ever meet.
Old 04-17-2018, 10:10 AM
does the hf unit work well for you Ron?
Old 04-17-2018, 10:21 AM
Surprisingly, yes. We have not had any issue with it since purchasing it last July. It is on if the shop lights are on so to speak. I would not have thought it would have lasted this long.
Ron Lee
Blackshear, Ga
HSD 5HP ATC
Aspire 9.0
On order:
Old 04-17-2018, 12:09 PM
Todd W Todd W is offline
I haven't killed the check valve yet, but I don't use the compressor that frequently. If I do kill a valve, I'll shrink the aftercooler coil to a single U bend with a drop, and then plumb the coil in after the tank instead. I do notice that long vent time!
Edit: I think if it dies, I'll see if I can move the unloader valve to the top of the cooling coil. Might be easier.
Originally Posted by de5 View Post
Todd, I made one of those DIY coils before I got this drier. When the compressor cycled off, the check valve would vent the air, but it took about 10 seconds instead of a quick hiss. I kept having check valve go bad. I replaced it 3 times in one year then finally got tired of it and bought the Quincy drier. Haven't had another check valve go bad in 3 years.
I'm just curious if you have had to replace your check valve.
Old 04-17-2018, 12:28 PM
ruun96 ruun96 is offline
We got a Quincy dryer with our compressor, but when it came time to service it we found out it needed European refrigerant and foriegn parts that were going to cost $$$$$$. So now we have an Ingersol.
Old 04-17-2018, 04:09 PM
Options Options is offline
Default Compressor & Dryer
I have a quote for a Champion VRV5-8 5hp 80 gallon 2 stage compressor (19.1 cfm @125psi) and Great Lakes GRF-20-116 20cfm refrigerated dryer, regulator and gauges.
What do you think?
Ron
Old 04-17-2018, 05:25 PM
de5 de5 is offline
Works for me...it ought to be a nice setup.
Charlie Hind
Cobra 404 ATC with 12 tool positions & 4th Axis (2012-present)
(2006-2012 - K2 CNC... sold in 2012 to buy the Cobra)
www.hindocarina.com
http://facebook.com/hindocarina
Old 04-17-2018, 06:35 PM
UglySign UglySign is offline
How about this instead of or add with a refrigerated air dryer.
My Compressor After-cooler Install
Sorry if I bring you to another site. Also there's tons of topics of
keeping moisture in the lines. Not 100% all but greatly reduced.
Depends how far you take it.
  #19
Old 04-17-2018, 08:27 PM
Thanks but the $850 for this dryer is cheap insurance and designed to work with this compressor. While yours looks very nice it's not something that I personally would want to trust.
