Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > Mozaik Software
Old 02-11-2016, 08:37 PM
rmfaires rmfaires is offline
Default Witness mark MDF doors
I am making some mdf doors for the first time. I am getting a small witness mark on the edge where the bit enters the material. Is this a programming issue or a hardware issue. Would plunge rate or ramps have anything to do with this. I don't know if I can control the ramping in Mozaik. Any ideas?
Cobra 508 ATC
Vcarve pro
Mozaik
Fusion 360
Old 02-11-2016, 10:52 PM
Tristan Tristan is offline
Send a message via Skype™ to Tristan
I had the same issue when cutting MDF. It seemed to be worse when the bit has a few hours behind its name. I extended the ramp (was ramping 20mm through the 16mm MDF). I extended the ramp to 40mm, and the problem was solved. My logic says that a slower plunge rate should also sort the problem out. As to how to do it in Mosaic, sorry, can't help there. I work with Aspire and EnRoute. But I can't see the you couldn't set it in Mosaic.
Hope you come right.
Tristan Brammer
CAMaster Cobra CR-609 ATC
2018 CAMaster Elite CR-609 ATC
WINCNC
Enroute 4 and Aspire v8 Design Software
AutoCAD, Autosketch, Sketchup
Razor CNC
Aspire v8
"Sawdust means Work in Progress"
Old 02-11-2016, 11:05 PM
Stinger3 Stinger3 is offline
You can set the ramping in Mozaik. If my rental did not just expire I would look where I set it. But, I know you can adjust it.
Stinger III
3.0 KW Spindle
Performance Package –Plus
Hurricane Vac Table
Recoil Indexing Lathe Ready
Old 02-12-2016, 07:02 AM
srhardwoods srhardwoods is offline
Here is how you'll control the ramping in Mozaik
- In the Optimizer, go through the process of optimizing your job, then you can go to each sheet and click on the button to the right to "generate G-dode"
- Then generate G code window will come up...
- click calculate
- then to the right, click edit
- the next window to open will give you all the options for ramp in distance, linear or zigzag, conventional, climb arc corners, onion skin etc etc
Let me know if you have issues I'll do screen shots.
Which MDF bits are you using?
Chris Vickers
Somerton Ridge hardwoods
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
Old 02-12-2016, 09:10 AM
johnb johnb is offline
There's a little simpler way to do it.
In optimizer click libraries then click tooling.
Click on the tool your are using .
Near bottom right where you select what type of operations this too is valid for there is an extra button
For options... set the ramp distance here.
Note if you go to this menu through the regular screen and not the optimizer menu you will not see these options.
Hopefully that helps.
Old 02-12-2016, 01:12 PM
Thanks guys that helps, I didn't see the options in the regular tooling library. I am using the vortex insert bits, they are cutting nicely.
Cobra 508 ATC
Vcarve pro
Mozaik
Fusion 360
