Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > Mozaik Software
Old 10-07-2017, 07:01 PM
jbiddle jbiddle is offline
Default Mozaik first attempts are cutting too deep
Hi, we're testing out the Mozaik software for the first time for some shop cabs, and the holes and dados cut fine, but the profiles cuts were .010 into the spoilboard. The spoil board was resurfaced and the Z0 reset (using Mick's program).
We cleared the locals before starting with a G92 command, put a sheet of ply on, turned on the vac and DC and off we went. We have the FTC and the first two tools, 5mm for holes and 1/4 for dado cut fine.
The last cuts were the profile using a 3/8" compression. It cut everything in one pass at 450ipm but as soon as the first part was about to be fully cut, the part let loose and the bit dug in and we stopped the machine. Not only was the part scrap, but we noticed the bit had been cutting into the spoil board by 0.010" for the entire cut. We thought we'd not recalibrated correctly and went about recalibrating to the top of the spoilboard by lowering the bit to the spoil board and recalibrated and then measured the tool. We then sent the spindle of the spoilboard and after entering Z0, the spindle went just down to the top of the spoil board and registered z at 0 with the z0 blue LED on.
We then restarted the program from where it had left off, slowed the XY speeds to 350 and started it up again. It started running, and when we paused the machine to check the depth, is was back to cutting about 0.010 into the spoilboard.
My thinking is that because we've not had this issue in VCarvePro, and the cutting depth went back to cutting the same problematic depth as before, something must be wrong in the Mozaik PP for out machine. Do you agree or is there something I need to rule out first? We are already are working on the feeds/speeds, but what about the cut depth?
Panther PT-408
3.0KW spindle
Spindle speed control
Performance package (FTC, Laser, C'balance)
Recoil ready
15HP FPZ regen w/starter
Auto relief valve
Vectric VCarvePro
Old 10-07-2017, 09:54 PM
ScottM ScottM is offline
You wouldn't have set a start depth of something other then 0.0 would you?
Not sure how that software works, but I know in aspire if I forget to reset it, I am cutting that plus the requested depth by accident at times if I don't catch it.
Camaster PT-408, 6-tool ATC, 5hp HSD, Servos, Hurricane
Old 10-07-2017, 10:43 PM
sgodding sgodding is offline
I don't have Mozaik in front of me right now, but check the setup for that compression bit in the optimizer. There is a parameter that you can set for profile cuts to purposely cut into the spoilboard. This is set BY BIT, not for all bits. I have mine set to cut 0.007" into the spoilboard because that ensures that the compression bit cuts all the way through the bottom veneer layer. When I have this set to zero, I get a paper-thin flashing that has to be sanded off. It may be set to 0.010 for you.
Steve Godding
D&S Artistic Woodworking LLC
Old 10-07-2017, 10:46 PM
How deep do you want to cut into your board? With my profiles I always cut .015" into the board.
Kyle Stapleton
Old 10-08-2017, 10:42 AM
srhardwoods srhardwoods is online now
That is a setting in Mozaik, so when you cut out a piece of ply with a compression bit, it will have a clean edge, and if there is any variation in your spoilboard, going .010 deep ensures you cut all the ply, and not leaving a splintered edge
Chris Vickers
Somerton Ridge hardwoods
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
Old 10-08-2017, 10:49 AM
In Optimizer, go to tooling and select your bit you use for cutting out parts, to the right you will see add for cut through
attached is a screenshot
Chris Vickers
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
Old 10-08-2017, 11:03 AM
I failed to save the number of who called and discussed Moziak with me,, Please call again !
Old 10-08-2017, 03:11 PM
you guys are right on the mark. The bit was set to cut 0.030 into the spoil board with that setting. When you look at the Gcode, it first sends the bit down by the material thickness, then the next line sends it further down by the amount in that setting. Thanks for the help, I'll make the changes and cut again tomorrow.
I saw saw that in the profile path settings, I had onion skin set for parts below 144 sq. in. or one side under 5". So my 6 x 25 part did not onion skin and got tossed off the table. I'll make changes to those settings as well.
Panther PT-408
3.0KW spindle
Recoil ready
Auto relief valve
Vectric VCarvePro
Old 10-08-2017, 05:06 PM
I changed mine to parts under 4". If you have a stretcher or toe or small part on the edge of the table, and your plenum is blocking air flow for a portion of it the onion skin works great. It's worth the extra time to onion skin than it is to recut. I generally get 25 sheets before needing to resurface the spoilboard
Chris Vickers
www.srhardwoods.com
Cobra 510
10HP ATC
Vacuum Table
