Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The File Swap Meet > Vectric 3D Files
Old 02-16-2013, 09:43 PM
Robert Alexander Robert Alexander is offline
Default Curved texture pattern
It took me a bit to figure it out for Mike Rintz. But I found a way to do a textured panel that curves. I had done a Aspire video using the same technique, but the pattern was going in a straight line. The trick to getting the lines to curve was to draw a curved line, then copy it and place one above and one below the lines I wanted to curve then use the distort tool. I have a file for any of you that want to see how to do it. This file uses a .5 ball nose for the carving. Also the file has 2 options, 1 for a fluting cut and the other for a texture cut.
Proud owner of a Camaster Cobra 410
Epilog Helix laser engraver
Corel X4 Autosketch 9 Aspire 4
"The economy is not as bad as we are led to believe. Many merchants report this year's going-out-of-business sales are much better than last year."
Old 02-16-2013, 10:17 PM
excellent!!
Old 02-16-2013, 10:51 PM
Jimwill52 Jimwill52 is offline
nice work! Thanks for file.
"If it was easy anyone could do it!"
Jim Williams, CaMaster Stinger w/recoil, FTC
http://expressionsofhonor.com
