Old 04-18-2018, 08:35 AM
TimPa TimPa is offline
we make them just under 1/16" then engrave and cut them on our laser.
Old 04-18-2018, 11:21 AM
Todd W Todd W is offline
Are you using plywood. I know model airplane places sell 1/16 and 1/32 birch plywood for a lot less than that stuff linked to on Amazon. Seems like solid wood might be prettier, but also more prone to warping or cracking.
Old 04-18-2018, 12:15 PM
carasel carasel is offline
Try wood on wood veneer. The back layer is perpendicular to the face.
If your spoil board was newly surfaced and you have good vacuum hold down. It probably would work. The 500 pcs you could get out of a 4x8.
Eddie Kitson
Cobra 5x8 ATC
5hp spindle
20hp regen vac
laser pointer
V carve 8.0
Old 04-18-2018, 02:19 PM
no, we use solid wood. doesn't warp as bad as you might think. also make business card same way.
OP you may fair better to prep the stock thin first, then carve. I would start thick, maybe 1/8", then work your way down until it stops working.
Old 05-23-2018, 01:38 PM
BCunningham BCunningham is offline
I appreciate everyone's feedback.
Brett Cunningham
Singer I, SR-24
HSD 1 HP Spindle
VCarve Pro 9 + PhotoVcarve
