Old 04-22-2018, 04:54 PM
Is the file you want to upload within the guidelines shown for the various attachment types? If not, it will not be uploaded...just a thought as I have been bit by that more than once.
Old 04-25-2018, 03:00 PM
SCHEPEBC SCHEPEBC is offline
If you are using and upcut bit you would have some lifting of the edges. What I have found works is cutting with and upcut first to "hog" out majority of the material then switch to a downcut for a finish pass to bring it to size. Just watch how much you cut with the down cut and depth of passes so not to generate too much heat to start a fire.
