Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Panther Series
Old 08-30-2018, 03:57 PM
mfase731 mfase731 is offline
Send a message via AIM to mfase731
Default Steps in wood
We recently received a brand new Panther 408, and while face milling / fly cutting we are getting steps in finish. Can you tram the head in, or has anyone else had the same issue.
Our table was out .090 inches in z plane to start also.
Thank you for any help at all,
Mike
Old 08-30-2018, 05:50 PM
Gary Campbell Gary Campbell is online now
Was the surfacing done as an offset pattern or as a raster in the Y direction?
Old 08-31-2018, 08:46 AM
Can you explain this in a little more detail? Was the frame leveled prior to routing?
Old 08-31-2018, 07:45 PM
If you mean when you first got your machine and took the paint off the plenum.
My machine had one corner that was really high 1/8 of an inch or better.
Just go until all the paint is gone.
After you skim one side of the mdf for your spoilboard flip it and glue the skimmed side down, let it set up and then surface the top side.
When I did my first surface there were scallops or lines on my spoilboard. I had to tram the spindle.
It can be done easily and with scrap or you can buy a special micrometer tool.
The easy way for me was a 3ft piece of 3/8 tubing that I bent into a long Z shape. I think I ended up with a .015 shim behind the spindle, it was quite a ways out.
Old 09-11-2018, 01:39 PM
Default tramming the head
I buy a new machine and have to tram a head in? Only way I get a flat surface is in the x axis.
Old 09-11-2018, 01:45 PM
Hi Gary,
It was done in raster at a 90 degree. so I ended up with very big valleys. Only way to get rid of steps is at 0 degree across table. I sent a picture to support of the problem. really upsetting that I am having the amount of problems we are incurring.
First it was a software issue to deal with than a mistake in the programming on ATC that crashed every time
Frustrated in Michigan,
Mike Fase
Old 09-11-2018, 06:04 PM
Erik Land Erik Land is online now
I have three cncs. one cost me almost 200,000 and yes the installer had to tram the head. these machines are subjected to a lot of jostling in the shipping and there is only so much fine tuning they can do at the plant before shipping. you need to get it in your shop and leveled checked. part of that checking will be to do the fine tuning and to tram, or at least check the tram is part of that. I guess I look at it as no different than doing your first surfacing of the bed.
Erik
[QUOTE=mfase731;75990]I buy a new machine and have to tram a head in? Only way I get a flat surface is in the x axis.[/QUOchTE]
Erik Land
Dorena Oregon
Cnccutter@gmail.com
Stinger I SR24 11/27/17
Performance package Pro:
2" Gantry Lift
FTC Fast Tool Change
Laser Cross Hair
Counter Balance
Tee Track Table
Kent Dust Shoe
Aspire 9.5
Rhino
Old 09-15-2018, 08:27 PM
Mike...
Tramming the cutting head is something that is almost routine maintenance. Especially after shipping. They are trammed with a gauge at the factory, but the real test is to put in a large diameter surfacer and skim off the table.
If you don't know how, there are dozens of posts here on the forum, or post back here and we will help you out.
Old 09-17-2018, 06:30 PM
Default Tramming Head and Machine stalling out
Yes, I finally realized with some prodding from you guys on the Forum that the head needed to be trammed in. It was out .07 of an inch.
Now we are working past the issue of the machine shutting down during an extended cut. did the grounding of vacuum hose as recommended Friday and it still shut down on me with no fault conditions.
Mike.
tram
