Old 03-01-2014, 05:10 PM
Timberwolf Design Timberwolf Design is offline
Well after missing with this for a few hours I got the laser back to .008 off the bit mark. I can live with this but it would be nice to know it was .000 LOL.
Thanks for your help Mick
Old 03-01-2014, 07:47 PM
Now you have gone this far, why not add .008 to the "laser_zero.mac" file in the direction you need ...... should be any easy fix, then as you stated you will have the correct offset.
Old 03-03-2014, 11:55 AM
Hell of a weekend but I did get the laser to work.
I went home Friday night had a cigar and a bourbon and thought this out clearly.
After working in the Air Force communications and 22 years as a AutoCAD/3D solid molder (air Force simulations) I kept telling my self in AutoCAD and Solid Works (X,Y,Z or 0,0,0) is where you set it no matter what Right. Then why wont this system hold the settings that Camaster had me set and the same directions from Mick?
Well about 11:00 pm it dawned on me what has happened and the ONE IMPORTANT step that Robert at Camaster or Mick for got to mention.
I hoped back in my truck and went to my shop. Sure enough as soon as I initiated my machine and told it to go to X0,Y0 it went right to the spot.
What was the Imporetant step nobody mentioned? REBOOT THE COMPUTER after we went in to WINCNC and changed the settings. The original settings in WINCNC (Laser-Zero) were in cache memory and the settings that Robert (same with Mick) ask me to change would not take effect until the computer was rebooted and then WINCNC would acknowledged the new settings.
Simple but stupid of me all I had to do is reboot my computer after making the changes......
Old 03-03-2014, 01:05 PM
Bart...
Actually you shouldn't have to reboot the computer, just close down WinCNC, and restart. WinCNC reads those files only on startup.
If you look over the manual, it is repeated numerous times.... each time you make a change you must restart WinCNC to activate your changes.
Take a peek at the WinCNC manual, page 43. It will mention the restart in the firsty paragraph, and then shows how and what each of these parameters changes.
Old 03-03-2014, 01:17 PM
Then something is drastically wrong with my system. Because the setting DID NOT take effect until I rebooted the computer ???????????
Old 03-03-2014, 01:19 PM
I have been telling Luke at Camaster that something is wrong with my system.
At least once a week I have to re-establish Z0 or my system does not perform right
Old 11-21-2017, 04:51 PM
moell54 moell54 is offline
Default Did I Tell You I Love This Forum?
While barely getting my feet wet on the new Panther I followed Mick Martinís post, above, to EXACTLY adjust the laser offset from the tip of a bit.
Worked like a charm.
Thanks!
Aubrey Blalock
Panther 404 (Nov '17)
3KW HSD
FTC, Laser, Counter Balance, 2" Gantry Lift
KRS Keypad
WinCNC, Aspire 9.0
