Old 10-18-2017, 05:18 PM
crosetti crosetti is offline
Default Machine thinks it's hitting the limit
I've ALWAYS parked my Stinger when done, but I forgot last time. I left the gantry at the far end of the table. Now when I start it & try to initialize it thinks its hitting the Y soft limit. Any thoughts? THANKS!
John Crosetti
Stinger III, 3.0 KW Spindle, Hurricane Vacuum
Old 10-18-2017, 06:07 PM
That should not matter,, are you initalizing from a cold boot ? do you have an ATC if so you may have to remove the tool in the spindle (Always check to make sure it is not spinning) Just safety always
Old 10-18-2017, 06:20 PM
Never mind... operator error. there is no problem
John Crosetti
