Old 09-11-2018, 12:54 PM
Default Mach3 -Keyboard .issues
Sooooo ..... I did something stupid, but not sure what.
Anyway, everything stalled out on me after plowing through about 9" of HDU with the router not turned on. It had been on the previous file, & I didn't change bits, so I must have inadvertently hit the switch. Anyway, I didn't get to the E-stop fast enough.
So, everything works fine again, except my arrow keys & PageUp/Down keys. New keyboard made no difference.
Any thoughts?
BTW, I'm on Mach3.
If you know exactly what the issue is & how to repair it , 1-800-265-1571
TR
TR
www.trmacsigns.com
CAMaster MC4836 named Jemima
Aspire 3.5
CoreldrawX3
Old 09-11-2018, 01:26 PM
I don't know anything about Mach 3, but can it be assumed that you shut everything down, checked all cables, etc., restarted and reinitialized? That would be the first thing I would do when something bizarre is going on...
Old 09-11-2018, 01:27 PM
Ger21 Ger21 is offline
Does the machine still move when you run g-code?
If it does, try Config > Hotkeys
Gerry
JointCAM - CNC Dovetails & Box Joints
Old 09-11-2018, 02:10 PM
Gerry, it'll still run G-code, yes.
Config Hotkeys just has a bunch of numbers there. Beyond me ....
TR
www.trmacsigns.com
Aspire 3.5
CoreldrawX3
Old 09-11-2018, 02:56 PM
I don't have a copy of Mach3 in front of me to look at.
If it says X+ or X++, click in the box next to it, and it should ask you to press a key. That should be the right arrow key.
I would try one, and see if it works before changing them all.
Close and restart mach3 after changing the key.
Gerry
Old 09-11-2018, 03:01 PM
Got it. I had to reset "jog". that was all.
Thanks, though. I'm unbelievably stupid with this technical stuff.
TR
www.trmacsigns.com
Aspire 3.5
CoreldrawX3
Old 09-17-2018, 07:30 AM
neal_meyers_jr neal_meyers_jr is offline
CAMaster Cobra Owner
Send a message via Skype™ to neal_meyers_jr
Cool
I had a similar problem and noticed the number lock key was NOT locked...
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Aspire 4.0, WinCNC, Rhino, Mastercam, Autocad, Catia.
