Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > General Discussion
Old 03-17-2018, 06:37 PM
MoDuhon MoDuhon is offline
Default Dust boot is stuck
Is there a way to get my dust boot unstuck? I can see it twitch when i hit the up/down button but it won't move...
Wright City, MO (Just outside STL)
CAMaster Panther 510 ATC
5hp HSD Spindle
6 Toll Rotary Changer
2 Hurricanes
V Carve Pro
Old 03-17-2018, 06:59 PM
Default Working but....
It's going up and down now (with a little elbow grease) but it moves in an irregular motion. Is there something i should do?
5hp HSD Spindle
2 Hurricanes
V Carve Pro
Old 03-17-2018, 08:40 PM
look to see if it is binding at the zplate when in up position, also there is a small air valve in line at the manifold , probably a tiny silver dial type,, these control air in and out, make sure it is the right one and not the one for the lift
Old 03-18-2018, 09:51 PM
Rlee1972 Rlee1972 is offline
You need to adjust your air pressure on the side of the spindle (not at the compressor). When facing the front of the spindle, look over on the right side of the unit and you will see two small round knobs that the small plastic air lines are a part of. Upon closer examination, you will see the knob marked with an arrow for "+" and another for "-". Keep adjusting it bit by bit until you have a continuous smooth "up/down". If still not sure where, ask Luke or Michael to email you a picture of the adjustment. I had to do this as well and it is to do every time we take our boot off to run lids.
Ron Lee
Blackshear, Ga
2018 Cobra Elite 5 x 10 ATC
20 Tool Holder
25HP Regen Vac
2017 Panther 408
HSD 5HP ATC
6 Tool Rotary Carousel
Aspire 9.0
PhotoVcarve
"You never learn anything by doing it right."
If that were true, I would be one of the most intelligent people you would ever meet.
Old 03-20-2018, 09:48 AM
Default Thanks,
Will do, Thanks guys.
5hp HSD Spindle
2 Hurricanes
V Carve Pro
