Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers > MC CNC Routers
Old 12-15-2015, 08:19 PM
Default Z losing height
4836 Mini Cobra
Z started losing height halfway through a long file Tried a shorter file later & started dropping right off the start. Bearings in Z seem to be grinding ( they were fine when I started) .... would this cause the Z to drop.
It doesn't appear to be the driveshaft, or the connector.
TR
www.trmacsigns.com
CAMaster MC4836 named Jemima
Aspire 3.5
CoreldrawX3
Old 12-15-2015, 10:18 PM
TR...
If there is a mechanical bind, then your stepper could be loosing steps on rapid up movements.
Disassemble, clean, lube! Let us know if you need any help
Old 12-15-2015, 10:33 PM
If you were to surface your spoil board, does the Z end up at a different height at the finish compared to the start? Or does it only lose height when you have Z movements?
Old 12-16-2015, 03:52 AM
Thanks guys.
I just checked the last cut I made ( tried it on a new piece) .... it was a profile cut with a .125" BN, set to .25" deep. It appears to have dropped immediately to .50, & didn't raise enough to clear the surface when it moved to a different spot. Then it maintained its depth throughout the remainder of the cut.
The previous path, on the original board, was a series of pockets with the same bit set to .65" depth, but because of the previous layers it was only removing .15" on HDU. The first few pockets were fine, but then, every pocket got deeper until it was 1.25" . The screen said it was still at .65".
I was watching this all unfold .... up to .9" depth didn't matter.
So, I'm really confused now ....
TR
www.trmacsigns.com
Aspire 3.5
CoreldrawX3
Old 12-16-2015, 12:07 PM
CosmosK CosmosK is offline
There was another thread on here recently about a ballnut housing being loose. In his case, the ballscrew would spin, but so would the nut in its housing. The cylindrical nut is somehow held in the rectangular housing and it was not holding. He had to order a new nut.
2014 Stinger II (SR-44)
1.7 kW Spindle w/ speed control, Performance kit, VCarve Pro
www.cosmos-industrial.com
>Pen Marking Tools
