Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > The CAMhead Locker Room! > Kathy from Tonasket WA
Old 04-24-2018, 07:05 PM
Originally Posted by Kathy View Post
That was a typo but maybe just what I need right now. I do appreciate all your help. Will be starting this project later this week.
No worries, Kathy. It certainly isn't the first time!
Be sure to cut a test piece to make sure you are happy with it before delving right in. The white bead board is probably the worst since it is essentially steamed together to make a board - BUT as I said, crank that RPM up as high as it will go + a 4-flute end mill to lighten up the chipload. Try test cutting @ 60 IPM and have a look....then 90....then 120IPM at high RPM. See what gives the best finish.
When I was a CNC trainer, I'd instruct noobs to test cut their parts using either the pink or blue insulation foam before they cut into expensive or exotic lumber. This gave them the ability to view what was going to happen without the chance of breaking a bit. I am not sure if you can substitute for the pink/blue insulation foam with this project, but it does cut better because it is extruded (no beads) and it is 2-3x denser. The pink/blue stuff does V-carve pretty well as long as the RPM is high and feeds are 60-90 IPM.
Just keep in mind that most packaging is press formed in heated dies - this gives it a nice finish and increases the density. I don't know what your exact application is without seeing it - so take what I say as generic knowledge. I'm saying that because I am hoping the customer isn't expecting heirloom quality furniture using $7 oriented strand board (OSB) plywood...or something to that effect...right?
Let us know how you make out.
-Brady
Old 04-24-2018, 11:05 PM
Kathy Kathy is offline
Thanks Brady, I will let you know how this turns out.
Kathy
ALLSEW Embroidery & Engraving
StingerII FTC (4 hole)Vacuum Table Aspire3.5 WinCNC
EpilogLaser 60W Corel Photoshop Elements
SWF Embroidery Machine 1202-45 WINGS Software
www.allsewengraver.com
"from silk to stone we've got ya covered"
Old 04-28-2018, 11:29 PM
Default foam project finished
I want to thank everyone who stepped up to help me with tips and pointers for cutting inexpensive foam. Got the job done and it went very well, The customer is happy. In return for doing this I will be getting a greenhouse. So very happy. (Something I have always wanted)
Thanks again, Kathy You guys are the best!
Old 04-29-2018, 01:04 AM
Rlee1972 Rlee1972 is offline
So happy to hear for you!
Ron Lee
Blackshear, Ga
2017 CAMaster PT-408
HSD 5HP ATC
6 Tool Rotary Carousel
Aspire 9.0
On order:
Cobra Elite 5 x 10 ATC
20 Tool Holder
25HP Regen Vac
"You never learn anything by doing it right."
If that were true, I would be one of the most intelligent people you would ever meet.
Old 04-29-2018, 12:46 PM
Fantastic! Glad you were able to pull it off.
-B
