Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > The CAMhead Locker Room! > Mick Martin
  #51
Old 08-08-2017, 05:24 PM
adirondak5 adirondak5 is online now
Are you entering the machinable length of your spoil board or the total length ? Looking at the specs on a Stinger III it looks like 49" x 96" machinable area , if you enter a larger area than your machinable area you'll get the soft limits exceeded error .
Herb Holmes
Performance Pkg
Slotted table
WINCNC
Aspire 8.505
Porter Cable 2.25
CAMaster Stand
I've got to many clamps , and sometimes they are not enough
  #52
Old 08-08-2017, 08:47 PM
Also, make sure you have blue boxes by the x and y too. If you have green ones, type in G92 and look up in the WinCNC book to learn what it means.
  #53
Old 08-09-2017, 09:38 AM
Mick Martin's Avatar
Mick Martin Mick Martin is offline
CAMaster Cobra Owner (MOD, KOTR)
Originally Posted by jwdoerr View Post
Hello Mick and all others,
I am a new owner of a stinger 2. I was trying to install the spoilboard wizard and my computer keeps detecting malware and will not let me install the file. Has any one else had this issue? Is there an updated version of this wizard. I really think it is an amazing tool and would love to run it.
Jimmy D
Other members have had better luck is they download it off my website Here
Mick Martin
mickmartin3@comcast.net
CAMaster Cobra 508 ATC + Recoil + Popup Pins
Digitize Touch Probe
Wincnc Handheld Serial Keypad + Wireless Pendant
Hurricane vacuum
WinCNC + Aspire 9.5 + PhotoVCarve + EnRoute 5
www.customarchitecturalsignage.com
www.mickmartinwoodworking.com/
The search function on the forum is your best friend!
  #54
Old 08-09-2017, 09:52 AM
Originally Posted by JStiver09 View Post
I am attempting to use this file for the first time surfacing my spoilboard on a brand new machine. When I go to use it, I get an "error - soft limit exceeded (Y+). I am using a stinger III and entered the exact dimensions of my spoilboard (49"x121"). Thoughts?
You can measure the actual width of the spoilboard and enter that as your actual width into the spoilboard wizard.
To find the machinable spoilboard length (Y axis) rather than the actual spoilboard length I do the following:
- If you have a green box next to X or Y then type G92 into Wincnc and press enter.
- Now slowly jog the spindle/router down the Y axis either till it hits the end stop or it gives and error message, view the value of the Y axis and enter that value MINUS 0.1" example value according to Wincnc was 96.8" so enter 96.7" into the spoilboard wizard for the Y value.
Mick Martin
Hurricane vacuum
  #55
Old 08-09-2017, 08:58 PM
JStiver09 JStiver09 is offline
Thanks guys,
I got it to run, by inputing the machinable length instead of actual length. Thank you!
Stinger III
3.0 (4.2 HP) spindle
Performance Package
  #56
Old 06-05-2018, 11:58 AM
EnvisionIT EnvisionIT is offline
Using the spoilboard wizard and it is working fine. But had a question
At the end, I type in Z0 and the bit lowers to the table
I then type in M37Z0 as asked and absolutely nothing happens...
I would assume that the machine would calibrate the switch again with the bit, however WinCNC does not respond to the command, i.e. it does not display anything on the display.
Am I missing something?
Signpro 408 / 5HP ATC Spindle
Oscillating Tangential Knife
Laser Pointer / Mister System /Remote Keypad
15HP FPZ Vacuum
Alco 200 Dust collector
WinCNC 3.0 / Aspire v9 / PhotoVCarve
It's a hobby with some very expensive toys!
  #57
Old 06-05-2018, 01:25 PM
If you look in your WINCNC.ini file you can determine how far you can over-cut on the Y Axis as the limits are in that file. On my Stinger II, I was able to hit 50", which provides a hair more surface in that direction.
(Mick, this utility is the bee's knees... thanks for creating it!)
  #58
Old 06-05-2018, 08:39 PM
After you type in Z0 and the bit is on the table if you just hit the “calibrate switch” on the wincnc screen you shlould be fine. The bit should raise, jog over to the ftc pad and do the measurement. You should then have a blue box next to the Z box on the screen.
  #59
Old 06-05-2018, 11:42 PM
Great tnx, that is what I ultimately did. Just wanted to make sure I something was not wrong.
15HP FPZ Vacuum
  #60
Old 08-26-2018, 09:11 PM
JomoTa JomoTa is offline
Thanks Mick Martin for this app. I did a dry run and everything looks good to go.
Industrial/Furniture designer in the evening and weekends
instagram.com/jomofurniture
Stinger I SR23
