Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Safety
Old 03-18-2013, 08:43 AM
Luke Bennett's Avatar
Luke Bennett Luke Bennett is offline
CAMaster Tech
I thought someone was barbequing. Ain't nobody got time for that.
Sorry had to go there glad all is OK and the fire was small.
Luke Bennett
CAMaster CNC Tech
www.camaster.com
Frankenstinger 25x48 custom machine
Old 03-18-2013, 08:51 AM
jzlitz jzlitz is offline
Thanks Jim for posting, that helps us newbies pay a little ( a lot) more attention!
God Bless,
James & Zelma (Psalm 18:2)
"Inscriptions Of The Heart"
Texas
~A man is only as good as his word~
Old 03-18-2013, 10:08 AM
anix396 anix396 is offline
Thanks for posting. It is easy to get complacent and take things for granted. It never hurts to be reminded. That could sure be a wake up call.
Al Nix
rsgraphics@surfsouth.com
Stinger III, FTC, 8"Z
1.7 KW Spindle, Laser
WINCNC, Aspire
40W GCC Laser
Wide Format printer, cutter & Laminator
Adel, GA
Old 03-18-2013, 11:01 AM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
Just a reminder of what it could be.
Here's my spindle,,,,with the hole thru the spoilboard,,,,,black smoke everywhere....
Oh Ya !
Michael
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com
mm@mezalick.com
Old 03-18-2013, 11:10 AM
Mike made me fell soooo much better after he did that !!
Old 03-18-2013, 01:24 PM
Jimwill52 Jimwill52 is offline
Default Fire Safety
Thanks for sharing your fire stories, I'm glad they weren't really destructive fires. I have seen many shop fires that were much worse, most fires that activate the sprinkler system have already done lots of damage and usually put folks out of business for a while. "Clean agent" fire extinguishers are the safest and cleanest for sensitive equipment. Halon was one of the best but is classified as 'ozone' depleting and was taken off the market. There are several replacements that work great including DuPont FE 35 and Halotron-1. These work by actually altering the chemical process of the fire and work very quickly before much damage is done. You can buy clean agent systems to put over your CAMaster and other equipment... they are kind of pricey. A small extinguisher would be around $150 and up to a grand. A little goes a long way... IF you catch it early enough. I don't know anything about 'Badger Fire", it's just an example I found quickly.
http://www.badgerfire.com/utcfs/ws-6...N_HALOTRON.pdf
"If it was easy anyone could do it!"
Jim Williams, CaMaster Stinger w/recoil, FTC
http://expressionsofhonor.com
Old 02-08-2014, 06:59 PM
BUMP !!!!!!
Old 07-13-2017, 10:33 AM
staffnon staffnon is offline
I posted this back on 2-16-2017
check out this site http://www.macthefireguy.com
They have fire suppression systems for RV and OTR (over the Road truck). That have systems for engine compartments, electrical panels, and other spaces.
If they can withstand the stress and movements on a vehicle then they can probably stand the movement and motion of the CNC's
Some of this systems are the size of a rattle can of paint.
Think outside the box on fire suppression for your CNC.
I guess I need this disclaimer for the PC police.
I do not profit from this info.
Old 03-21-2018, 07:33 AM
Sawdustmedic Sawdustmedic is offline
Default phenolic top and fire?
Originally Posted by james mcgrew View Post
on saturday i was doing a training session with the x3 machine, we were running a file that i had made the mistake of asking a 1/4 inch bit to cut through the material, the bit cut about 10 feet in cut length and snapped, we removed the bit (seemed warm but not hot) and left the vacuum on to hold the material while we went into my office to rework the pass depth on the file.
in just a few minutes one of the guys in the shop said there was a fire, on the way to the fire i still did not know what was burning, i thought first to grab a fire extinguisher (they are located in many places and all corners and entrances as well as passages thru the building) we got real lucky time wise.
while we had removed the bit a small ember had begun to burn, the vacuum gave it wind and direction and no one could see it, about the time someone smelled it it broke throughthe spoil board surface.
i hope all reading this realize size of machine does not matter, they are made up of two things
1) electrical parts
2) parts that create friction
be careful, pay attention. my x3 is a god send and i would be as hard pressed as any to replace it and or pray i do not burn down the building or worse
my hope is this will help the new and old cnc'r
jim mcgrew
Newbie question, does the phenolic top burn as quickly as the mdf?
Thanks Bill
Old 03-21-2018, 08:39 AM
Bill...
I don't believe that the phenolic burns, or at least wont contribute to the fire. That said, everything on top of it will, and will be fanned by the spindle/router cooling fans and multiplied exponentially with vacuum hold down.
All damaging CNC fires have one thing in common. The operator was ONLY gone for a short period of time.
Your machine does not have to be large, it does not have to have vacuum, it simply has to have an MIA operator.
Reminder: https://youtu.be/D2xoxPlDnW4
