Old 01-16-2013, 05:32 PM
David Warkentin David Warkentin is offline
Default Need some help here...
I am trying to make this bootjack for a friend. I can't seem to join the open vectors. I can't even find them. Can someone help me? When I get it fixed up I'll post a file for everyone to use. Thanks!
David Warkentin
Panther 4x8
Laser cross hairs
Recoil
Hurricane
Sold-
What a load of fun!!!
www.bodkacoffee.com
Old 01-16-2013, 05:46 PM
neal_meyers_jr neal_meyers_jr is offline
CAMaster Cobra Owner
Send a message via Skype™ to neal_meyers_jr
Cool
David right click on the design and one of the sub menu choices is select "ALL OPEN VECTORS" click that choice and it should show you the open vectors. Hope it helps.
Owner with Recoil
Neal Meyers Jr
Guyton Ga
Aspire 4.0, WinCNC, Rhino, Mastercam, Autocad, Catia.
Old 01-16-2013, 05:50 PM
I have looked for all open vectors but it just turns the whole areas where they are pink or whatever color that is. It doesn't show me where they are. And if I try join open vectors it still won't do it...
David Warkentin
Panther 4x8
Laser cross hairs
Recoil
Hurricane
Sold-
www.bodkacoffee.com
Old 01-16-2013, 05:58 PM
in the hatch section there is a bunch of crossover this needs to be fixed
back at 8 pm
Old 01-16-2013, 06:03 PM
Thanks I'll work on that.
David Warkentin
Panther 4x8
Laser cross hairs
Recoil
Hurricane
Sold-
www.bodkacoffee.com
Old 01-17-2013, 08:25 AM
Hi David,
The open vectors in the cross hatch area are hard to close in that design. If you use a profile toolpath you don't need to close the vectors. You can still use your Vbit just adjust the depth of the cut to maybe .06. I have Aspire so I don't think you can read my crv file or I would post it.
Ask if this doesn't help.
Mark
MC4848 (mini Cobra) 48 by 48
Aspire 8.0
Old 01-17-2013, 08:38 AM
Yeah that works. My only problem yet is that when I try to profile around outside it gives me the message to check tool can fit into vectors at machining depth. If I click on inside it goes ahead and calculates and shows the cut on the outside. How did I confuse it to think the inside was outside and vice versa?
David Warkentin
Panther 4x8
Laser cross hairs
Recoil
Hurricane
Sold-
www.bodkacoffee.com
Old 01-17-2013, 08:43 AM
fixtureman
Guest
Posts: n/a
Make 2 profiles one for the cross sections on the line and then another for the rest outside the line
Old 01-17-2013, 08:45 AM
David,
I guess I could have put the results of my toolpath picture on the forum. Is this the results you want?
Mark
Aspire 8.0
Old 01-17-2013, 08:49 AM
When you profile cutout the part you do need another toolpath and you would want to use an end mill probably 1/4 and use tabs or another way to hold the part down.
Mark
Aspire 8.0
