Old 04-03-2013, 11:05 AM
JustWood JustWood is offline
Default Looking for a Zero Clearance Insert template
Is there a template Zero Clearance Insert for a Jet tablesaw out there? Below is what I like to cut out with the Stinger 1 when I get it. If not I guess I'll have to make a pattern.
George
______________________
CAMaster Stinger 1 FTC
Porter Cable 3.25 HP with counter balance
PhotoVCarve
Old 04-03-2013, 12:09 PM
George, not what you’re looking for but here’s one I made for my right tilt Unisaw. I think it could be adapted to the Jet and made out of a hardwood like maple. These were selling for over $100 15 years ago. It could be a money maker.
Let me know if you’d like the dxf file.
Bruce
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 04-03-2013, 12:34 PM
George,
If you can get the dimension of the insert it would be easy to make, I make mine out of MDF, several at a time http://www.rockler.com/articles/zero...aw-inserts.cfm
Old 04-03-2013, 12:58 PM
rtp_burnsville rtp_burnsville is offline
For a quick insert get some carpet tape and a piece of baltic plywood. Tape a piece of plywood to your insert. Take a router with a flush trim bit, carefully adjust so you don't hit the original insert and route a new insert plate. Mark and drill a couple holes and you are done. If you need adjusters on your new plate a couple small sheetmetal screws work fine.
I have done this several times, works great.
Robert
Stinger I Router / WinCNC
SprutCAM, V-Carve,ZW3D
Tormach PC1100 / Mach3
Old 04-03-2013, 01:20 PM
I make mine out of .5 solid surface,
trace one or scan in 11 x 17 scanner then tweak in aspire VCP to fit after that make as many as you want
