Old 09-17-2013, 08:20 PM
big papi big papi is offline
Default Laminated MDF
I am going to build some detailed shelves out of laminated mdf. I have a few questions. Is all laminated mdf the same? I don't want to go to the local big box store and buy some garbage that will fall apart right away. Secondly, what kind of 1/4' tool should I use and a what rpm and feed rate? Lastly, is the "iron on" edging a quality product?
Big Papi (John Smith)
Camaster 508 ATC / WINCNC / Aspire
Old 09-17-2013, 08:41 PM
Some "Melamine" (Thermafoil) is better than others, basically you should not have a problem,
to get a good (both sides) cut it is best to use a Compression bit, I far prefer a 3/8ths but a 1/4 inch works well, I cut at 15-16 k rpm and 400 ipm
for a really good cut run one file to cut thru to say .7 of a .75 material, make sure first pass is deeper than the end flutes of the compression bit, (Generally about .25" +) then run a second file with a start depth of .7 and a cut of .055 the vac will hold well and there will not be a lot of cut pressure on the last pass..
if you want to use a .25 down spiral then cut to say .72 leaving and "onion Skin" and cut parts out with a razor and just sand off edge with a 120gr block.
Iron on in big box stores can be pretty dry and not hold so well, may want to purchase from one of the better known woodworking sites (woodcraft, formwood, I like wisewood) the adhesive quality will be better, iron on can be good it is up to the adhesive
Old 09-17-2013, 08:44 PM
http://www.wisewoodveneer.com/store/...d-Edgebanding/
Wisewood may not have white pvc or mel EB. Fast cap has a preglued peel and stick we use a lot of for field work (good stuff)
http://www.amazon.com/FastCap-FastEd.../dp/B0006NNK8U
edgeco is another good one http://www.edgecoinc.com/edgeco_form.asp
Old 09-17-2013, 08:49 PM
Some how i knew it was going to be you (Jim) that would come to my rescue. Thanks again for all of your help. Do you ever have any free time? LOLhttp://www.camheads.org/images/smilies/7.gif
Old 09-17-2013, 08:52 PM
http://www.wwhardware.com/edgemate-p...-and-stick-pvc
these fellows sell Dolken which is a real leader in the EB Business
Old 09-17-2013, 08:54 PM
When you have as much fun as I do with a CNC it is 24/7 !
I prefer laminated plywood
Old 09-17-2013, 08:56 PM
Mick may be right, you may want to find a cabinet supplies wholesaler, (not in ones normal shopping) in your area, what city are you in?
Old 09-17-2013, 09:05 PM
this is where you want to get what you want !!
Wood Werks Supply Inc
1530 N Old Rand Rd
Wauconda, IL 60084
http://www.wwsupply.net/
Old 09-17-2013, 09:12 PM
even better,, all of these are in my AWI referral books this one will stock the best plys
http://www.owlhardwood.com/
