Old 05-08-2014, 10:43 AM
Brendt Brendt is offline
Default MDF Picture Frames
Does anyone have any files that they would be willing to share that they use for MDF picture frames. My wife wants a bunch of different designs to put pictures in around the house. Since she was nice enough to let me order my new machine I figured this would be a good project to get started with. I have drawn a few but was hoping someone had some already drawn up that I could use to get started.
Brendt Bowen
Stinger II 48" x 48"
V Carve Pro, Corel Draw X8
1.7 kwh spindle
Hurricane Black Box Vac
Oneida 5hp Super Dust Gorrilla
Old 05-08-2014, 10:45 AM
take a look here , at 4.00 a pop they are a Wife pleaser !! and she can pick what she wants !!
http://www.vectorart.com/store/index.cfm?q=frames&a=
Old 05-08-2014, 12:18 PM
Here is a sample of a lot of the frames I drew up. Most of these are double frames (larger frame on the back that has the keyhole slots on the back for hanging, then a smaller frame glued to the front to double the thickness). These look good painted two colours.
You will know the bottom frame because it has keyholes and a double line for the cutout (cut the back side first - the keyholes and the outer cutout line; I cut inside the profile of the outer cutout line, to a depth .15" less than full depth - then when I cut the inside profile on the front side the cutout comes free).
Old 05-08-2014, 10:39 PM
Russ,
I appreciate the help! This will be a huge help!
Brendt Bowen
1.7 kwh spindle
Old 05-08-2014, 11:02 PM
That's pretty neat Russell. What kind of sheet goods do you use, 1/2" Baltic birch?
You said you cut one side down to within .15 and then cut the other side, How do you keep the frames from coming out?
Mark
MC4848 (mini Cobra) 48 by 48
Aspire 8.0
Old 05-08-2014, 11:53 PM
These are 1/2" or 3/4" MDF.
The pictures in the frame need a lip to sit up against. So I cut the back of the sheet first, cutting that lip with a simple profile cut. On 3/4" stock I cut .6" deep with my normal 3/8" compression bit. Then when I flip it over, I cut 1/4" deep on the inside line, which releases the cut-out. Then I use an ogee profile bit and cut the outer profiles, about .6" deep, Then I go back with a 1/8" bit and cut the last .15". I hold the sheet down with a few Raptor composite nails, and have 3/8" dowels in each corner to index the sheet for when I flip it over to cut both sides.
Old 05-09-2014, 10:34 AM
Thanks Russell for the information. I got some details on the Raptor gun a while back but haven't acted on it. Seems pretty expensive but can see how it might work well especially in that situation.
Mark.
Aspire 8.0
Old 05-09-2014, 04:21 PM
Since I'm not cutting through when I cut the first side, I use vacuum hold down. Then I use the raptor nails on the second side cut because I have so many cut-outs. Just keeps it from shifting laterally.
Old 05-13-2014, 10:12 AM
bd007 bd007 is offline
I only have Vcarve. Is there a way to open this in Vcarve or is it Aspire only?
