Old 06-16-2014, 04:29 PM
Rick Vereen Rick Vereen is offline
Default Stinger Gasket Cutter?
A friend asked me to cut a small carburetor gasket for an old Farmall Cub tractor. Beyonce answered the challenge. My Stinger was surprisingly accurate even with something this small. Hope someone else can use the file.
Proud of my Stinger.
Stinger I Owner 2011
Aspire 8
Old 06-16-2014, 05:26 PM
KickIt KickIt is offline
Rick,
I see you used a ball nose bit, how well did it hold down? Have you tried the Drag Knife to cut this type of material?
This looks good.
Kevin
Kevin Stoops
Cobra's 508 ATC
Recoil, vacuum hold down.
Aspire 9, Photo w/Cut-3d, CPP
30W Fiber Laser
TDS Control Keypads - Inventor of the TDS/KRS Keypads
www.krscorporation.com for keypad support home
YouTube Videos
Old 06-16-2014, 08:17 PM
It held it down ok. Had a little issue at the end of the cut. The double sided tape helped the issue. It was a pretty stout piece of gasket material.
I have not tried a drag knife. First time cutting a gasket.
Aspire 8
