Old 08-14-2014, 10:39 PM
gachua gachua is offline
Default 1/8" EM with 3/4" Cutting Length?
2 Newbie Questions:
[1] When looking at router bit specifications cutting length is the "maximum" material thickness that it can cut correct?
i.e.
Cutting Diameter: 1/8"
Cutting Length: 1/2"
Shank Diameter: 1/4"
Overall Length: 2"
[2] Where is the best place to find a 1/8" EM (Or alternative with 1/8" cutting diameter) that can cut 3/4" thick material?
I have looked around at US Router Tools and can't find a 1/8" EM with cutting length over 1/2"
I did find a bit on Amazon that looks like it might work, but not sure as it is 4 flute and I remember reading the other night on the forum that 4 flute isn't a good idea for some reason:
http://www.amazon.com/gp/product/B00...A1IPHIYKH2PUAP
I've been making some samples of table numbers and other signage for a local wedding. All good on the signage, but instead of 1/2" for their table numbers they want it in 3/4". Some of the words and numbers due to their selected font requires the smaller cutting diameter.
Glenn Chua
gachua@gmail.com
Morrisville, NC
CAMaster Stinger III
Old 08-14-2014, 10:48 PM
I just ran across this thread on long router bits:
http://camheads.org/showthread.php?t...ht=router+bits
Glenn Chua
gachua@gmail.com
Morrisville, NC
Old 08-15-2014, 12:18 AM
dwolbeck dwolbeck is offline
Try Toolstoday. Thinks it's a compression bit. Kinda pricey.
Dennis Wolbeck
SR-44
3.25 HP router
T-slot table
Vcarve software
Old 08-15-2014, 08:40 PM
JeffP JeffP is offline
Look at Amana 51446 at ToolsToday- If I read specs right it's 3/4" cutting length, single flute upcut.
Jeff Potts
Cobra 508 ATC
VCarve Pro
Old 08-15-2014, 08:51 PM
http://www.ebay.com/itm/1-8-CUTTING-...item23389052e6
http://www.ebay.com/itm/1-8-2-FLUTE-...item58ae5a9f61
Old 08-15-2014, 09:01 PM
dld dld is offline
Originally Posted by gachua View Post
2 Newbie Questions:
gachua
is this 2d or 2.5d(3d)?
I use a 1.5" 1/8 bit to cut 3/4 mdf but use a 1/4 bit for a rough cut down to .70 then do the last .05 with a 1/8 bit with a 1/2 inch cutting depth.
It will cut closer to the shape than the 1/4 bit does but does it in 12 passes taking .0625 cuts. The majority of the material is cut with the 1/4 bit and make for a lighter load on the 1/8 th bit.
It takes longer but you don't have to worry with deflection of the bit like you would with a 3 inch 1/8 bit
It is one work around, not the quickest but it works
Dana Decker
dldecker@comcast.net
Aspire 8.something
Wincnc
2 1/4 hp router
Old 08-15-2014, 10:57 PM
Thanks all. Ordered a couple bits from the above recommendations.
@Dana - 2D. Workaround makes sense. I will give it a try. Thx !!
Glenn Chua
gachua@gmail.com
Morrisville, NC
Old 08-18-2014, 05:33 AM
Found this bit on Amazon. Not sure if I can use this? Doesn't say CNC in the description... Will do more research, but thought to post here to get some opinions:
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Glenn Chua
gachua@gmail.com
Morrisville, NC
Old 08-18-2014, 05:43 AM
Pete Cyr Pete Cyr is offline
Use this instead
http://www.amazon.com/LMT-Onsrud-60-...oated/dp/B0020
ATLOE/ref=pd_sim_sbs_indust_1?ie=UTF8&refRID=014VSFVJ4S2 E130RWREA
Pete Cyr
Aspire, WINCNC
Old 08-18-2014, 10:27 AM
JD69 JD69 is offline
Send a message via Skype™ to JD69
I have used this company:
https://www.centuriontools.com/
JD
Jack Davis
Stinger I - 1.0kw HSD Spindle
MACH3 - Vectric Software
