Old 10-21-2014, 08:08 PM
ericw ericw is offline
Default attaching spoil board
Okay Guys, another new guy question. Attaching 1" MDF spoil board with screws or glue or...?
Eric, Owner
Inner Mountain Rifle Stocks
Stinger II W/indexer
1.7 kw spindle
Old 10-21-2014, 08:15 PM
ChrisAlb ChrisAlb is offline
Stinger Owner
You will have answers that include both, but I believe that most glue their MDF spoilboard down.
Chris Albright
Stinger SR23, Porter Cable 2.25 hp
Vacuum Table
Z-Plate / Laser
Aspire 8.5
Old 10-21-2014, 08:39 PM
I glue mine but don't forget the thicker the spoil the less Z you have. A 1/4" might not seem like much but if you put a 2" piece on your machine you have to have room for the bit plus Z movement.
Mark
MC4848 (mini Cobra) 48 by 48
Aspire 8.0
Old 10-21-2014, 10:11 PM
ksmith1961 ksmith1961 is offline
I used both. Might have been overkill, but I used nylon carriage bolts and glue. With the nylon bolts I don't have to worry about ruining a bit when surfacing my spoilboard.
Stinger II SR34
Porter Cable 2.25hp Router
Performance Package (FTC / On-Off via G-code / Laser Cross Hair)
T-Slot Table
Aspire 4.5
Old 10-21-2014, 11:02 PM
Screws only, Id hate to think about having to eventually pry that glued one off, would be impossible without wrecking it.
If you got 1", plenty of room for countersink which should allow up to half a dozen resurfaces, and no worries about running into a screw. I use 3 rows of 8 screws, won't be going anywhere unless I want it to.
Old 10-21-2014, 11:12 PM
Bruce Page Bruce Page is online now
Screws only on mine to. I have the screw pattern as a tap file. Replacement will be as simple as laying the new board down and running the tap file.
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 10-21-2014, 11:30 PM
mbellon mbellon is offline
Default Attach spoiler board
Nylon screws here. I've never had any issues with them coming loose. It's trivial to change out the spoiler.
I countersunk the nylon screws so I can resurface the spoiler several times before I even have a chance of hitting the nylon screws.
- mark
Recoilless Stinger I with FTC, Laser, T-slot tracks
KentCNC brush head
Bob CAD/CAM (v27) (CAD/CAM)
Old 10-22-2014, 07:59 AM
bguthrie bguthrie is offline
Glue only. Just finished last weekend.
SR44 + Recoil
WinCNC, VCarve 8.5
https://www.facebook.com/GuthrieCNC/
Old 10-22-2014, 08:08 AM
When Doug says: "Id hate to think about having to eventually pry that glued one off, would be impossible without wrecking it.", I would submit that if it were glued, instead of prying it off, you simply surface it and glue another on top.
Along with being the most stable way of holding a spoilboard, it is also the least expensive, as you do not have to toss away the portion that is below the screw heads.
In any case, you (Eric) can choose from a number of methods to find what works best for you in the long run.
Old 10-22-2014, 08:12 AM
Nylon screws on mine , counter sunk 1/2"
Herb Holmes
Performance Pkg
Slotted table
WINCNC
Aspire 8.505
Porter Cable 2.25
CAMaster Stand
