Old 10-30-2014, 01:20 PM
KickIt KickIt is offline
Default Cat File
Attached is a Halloween Cat I made using Donek Drag knife.
I have a D2 and I believe the settings are close to correct for it. I have an Irwin blade in the tool and I am using the closest notch of the blade making the knife blade the shortest.
I updated the toolpath settings from the video adjusting the thickness of material and to two passes. One pass would work but I need to move the blade down and I do not know the offset for the moved position.
File should work with VcarvePro and Aspire
Cut Video
Kevin Stoops
Cobra's 508 ATC
Recoil, vacuum hold down.
Aspire 9, Photo w/Cut-3d, CPP
30W Fiber Laser
TDS Control Keypads - Inventor of the TDS/KRS Keypads
www.krscorporation.com for keypad support home
YouTube Videos
Old 10-31-2014, 02:05 PM
One more file with Bats...
Learning how to use the Drag Knife, it is a fun little tool.
Video of bats cutting with Donek drag knife D2
Kevin Stoops
Cobra's 508 ATC
30W Fiber Laser
YouTube Videos
Old 10-31-2014, 03:43 PM
Impact Image Impact Image is offline
I keep looking for a reason to get one of those.
Think it would cut .125" rubber?
Jeff Fuquay
Topside Custom
Impact Image Group
843-437-5406
Stinger III
3.0 KW spindle
Hurricane Vac
Prodim Proliner 8
Old 10-31-2014, 05:38 PM
Speedy Speedy is offline
Thumbs up
Thanks for the design
Larry
SR-44, 1.7KW SPINDLE with AIR ASSIST,
NEMA 34 MOTOR, DUAL RACK & PINION GANTRY DRIVES,
GANTRY LIFT, FTC, LASER.
AUTOCAD 2007-12, ASPIRE, CUT 3D, PHOTO CARVE
Advanced Fabrication Technologies, Inc.
SPRINGFIELD, MISSOURI
