Old 06-05-2015, 10:38 AM
Javier...
Its nice to put this "stuff" out to someone that understands. While you are at it, don't fall into the "I just throw 1000 inches per minute as a feedrate and let the controller take over" trap.
We all know a bicycle is slower than a corvette.
But what if they race in a gymnasium?
What if they must stay on the "line"
All the speed and acceleration of the Corvette will be useless when accuracy is required. Same goes for CNC machines, in many cases they will cut at lower quality when accelerating.
You will seldom get quality cuts when you exceed 1 inch per second (60 ipm) for each inch of geometry size. This will also be reduced by number and distance between nodes in the geometry. This means you may be able to pocket a postage stamp size geometry at 60 ipm, but you cannot expect to vcarve similar sized graphics at that speed.
Old 06-05-2015, 06:01 PM
CosmosK CosmosK is offline
Originally Posted by Javierunzueta View Post
In your (all forum members) experiences ...
I'll chime in now that you've opened it up to non-gurus :)
I had a good amount of machine shop experience before getting a Stinger. I never took the time to learn how to calculate speeds and feeds. Everything I knew was from asking people and observing. However, I took it upon myself to get educated on the subject when I bought a machine because the stakes are higher. I don't want to trash the machine, and I've seen enough trashed machines from people using them incorrectly.
RPM and feedrate combine for chipload. There are calculators out there, but I'd advise to find the equations and understand how they work and make your own calculator. For me, there are too many factors to take into account for me to try to learn by testing each combination. I need a starting point, and I don't want to overload the machine, so that's why I do the calculations. Might be overkill (for machining softer materials), but it's how I prefer to learn.
In general, why would you go faster? Time and money. In production, you want to make "in spec" parts as fast as you can.
I've had good luck doing details in hard maple with:
1/8" 2 flute: 6000rpm, 60ipm
1/16" 2 flute: 12000rpm, 30ipm
2014 Stinger II (SR-44)
www.cosmos-industrial.com
>Pen Marking Tools
Old 06-06-2015, 11:07 PM
Javierunzueta Javierunzueta is offline
CAM aster Owner
Default Taking it slow... Way too slow.
Well, I ran a few tests (See attached pics.)
Unfortunately, it showed somewhat inconclusive results. There was little (if any) difference between 20 IPM and 400 IPM in the grand scheme of things (Other than moderate debris size.) The 10 IPM produced fine dust and SLIGHTLY better quality, but not enough to matter.
I tried my " Diameter (MLCS) " Shank Spiral Downcut Endmill as well as my " diameter " Shank 60 Degree V-bit (MLCS) thus far.
I ran, as you can see, a series of fluted paths from 10 to 400 ips on some " cypress pieces at 12K and 16K RPM.
I must state, the 16K (albeit annoyingly noisier) produced an ever so slightly better cut overall so I'm probably keeping my speed there for most future work. Most cuts were crisp and quite similar with the only TRUE factor being the wood grain itself.
For sanding-free no-tearout smooth finish cut, the 16K at a staggeringly slow 10 IPS produced the cleanest look.
No burn marks anywhere at any speed/feed tested.
The Downcut spiral EM surprised me at it sliced through " of all three materials at 400 IPM without a hint of slowing down. I love this machine.
The V-bit faired just as nicely. What was absolutely fascinating was when my V-Bit, at the 60 IPM mark, started creating thin slices of wood peel (not unlike a smaller scaled version of my surface planer). I was a bit surprised because all the cuts I made were ACROSS THE GRAIN on purpose to gauge the tear-out. Quite an eye-opener for me.
All in all, the only discernible difference in quality (other than a slightly nicer cut at the turtle's pace) was from the actual wood itself.
I'll make more chips tomorrow. Good night all.
Javier Unzueta
Stinger 1, FTC, 2.25 PC, Touch Top, Vcarve Pro, PhotoVCarve, WinCNC
Miami, FL.
"I'm a firm believer in learning from my mistakes and failures, but I prefer to learn from others'!"
Old 06-07-2015, 09:09 AM
Terry Williams Terry Williams is offline
Here is a resource for some very handy links:
http://www.precisebits.com/library.htm
I spent many hours late at night googling various topics like wood hardness, Speeds & Feeds and virtually anything that had to do with CNC routing. This list is now the first place I go when I have a question.
The process for determining correct speed and feed in the following link works:
http://www.precisebits.com/tutorials...s_n_speeds.htm
If you are producing a part that you will make many copies of, this effort will be repaid many times over, but for a one-off, the payback isn't obvious, since you do have to invest some time and effort in the process.
Terry Williams
Cobra 510 with Recoil
Old 06-07-2015, 10:05 AM
You will get much better results by carefully choosing the woods you cut! Maple, cherry, and walnut seem to give me the best results.
The next factor is the bit. If I want a better cut, I often choose a larger diameter cutting tool. For the best edge finish, I use a 3 flute 1/2" low helix downcut. 14000rpm and adjust the feed speed to get the best finish.
Cutting 'conventional' vs 'climb' will also affect the cut quality. Usually conventional will give the best cut, but will also give the most tear-out. When the finished edge is important, I will often offset .01 and cut climb in a couple passes, then go back with no offset and cut conventional in a single pass. This gives a very clean edge (again, depending on the grain).
Cut quality is often higher when you increase the rpm and slow the feed speeds, but if you take it too far you will burn the wood. Cherry and purple heart are the worst for this, and its common on the corners where the feed slows down.
Old 06-07-2015, 11:27 AM
CAM aster Owner
Default Thanks...
Terry,
Thanks for the links. There was quite a good bit of information on it. Coincidentally, I was looking for a source for micro-bits for my stinger so this site was perfect.
Russell,
I've also had the same results with conventional vs climb cuts. I've been using that technique (offset climb and final conventional cut) recently and am thankful for the confirmation. I'm most definitely adding a 3 flute " low phlox dc to my arsenal. Thanks again for the advice.
Javier Unzueta
Miami, FL.
Old 06-07-2015, 11:33 AM
Default Moved to tech thread
Moved to a more technical thread subject
