Old 08-14-2015, 04:53 PM
TMiles TMiles is offline
Default Cutting MDO
We have several orders for cutting some shapes out of 1/2" MDO. I was wondering what suggestions you guys have for feeds, speeds, and bits to use. Does it cut like MDF?
Todd Miles
Sumter,SC
shbofsc@yahoo.com
CAMaster Stinger IV ATC
Vcarve
Hurricane Vacuum
2015 model
Old 08-14-2015, 09:24 PM
Hallex Hallex is offline
Camaster owner
Hi Todd
We have been cuttin a bit of mdo compression 3/8-1/4 bits leave a nice clean
Edge .use an onion skin! How fast really depends on size and shape. Give me an idea and I will try to help👌
Camhead FAN
Old 08-14-2015, 09:57 PM
My wife has a customer who want us to cut a lot of the 3 letter monograms.
Todd Miles
Sumter,SC
shbofsc@yahoo.com
Vcarve
Hurricane Vacuum
2015 model
Old 08-14-2015, 11:07 PM
Camaster owner
Those are kinda weird to cut. How are you holding it down?
Camhead FAN
Old 08-14-2015, 11:13 PM
Camaster owner
Have you cut one in MDF yet?
Camhead FAN
Old 08-15-2015, 12:09 AM
I think if you used a pressure foot and a 1/4" compression bit you could cut those fine letters in a single pass.
i'm impressed with these, but have yet to try one.
I think if you held the entire sheet down with vacuum, then cut the letters out with the pressure foot, you could do it in a single pass at a fairly rapid speed. Just need to make a mounting bracket that works with your spindle.
Just be sure not to do a tool change with the pressure foot attached!!
Old 08-15-2015, 09:11 AM
I have cut some mdf with a 1/4 down/up compression. It left a funny looking profile around the edge. I'm going to try just a 1/4" compression bit and see if it does better. I was thinking that the MDO should cut just like the MDF for the most part. As far as cutting thee things out, it is really tricky. We have a vacuum table but we do use a lot of tabs to keep the peices from moving. Cleaning up the part after it has been cut is usually where most of the work is. I will have to look into the pressure foot. I'm still not exactly sure I am getting a good vacuum from my table. I'm going to try a different type of mdf when I replace my spoil board next time. Do you guys have any suggestions for spoil board material?
Todd Miles
Sumter,SC
shbofsc@yahoo.com
Vcarve
Hurricane Vacuum
2015 model
Old 08-15-2015, 09:44 AM
No vacuum will hold that small of a piece. Vacuum is really meant for cabinet type work, where the pieces have enough surface area to create good resistance to lateral forces. A 10x10 piece will have 100 square inches, and your hurricane vac should be giving at least 8"hg, or roughly 4psi. So 400lbs of force holding that 10x10 piece down.
I use box store MDF and it works fine. A lot of people are saying use a higher quality LDF, but I've never found the need. If your spoil board is too cut up, you won't get the same hold down as you will from a freshly milled spoil board.
But I think that pressure foot is the ticket for your type of cutting. Even if you left an onionskin and then went back with the pressure foot to cut through the onionskin. I hate tabs, because they are so time consuming to cut out. I prefer leaving a thin onionskin (paper thin, just enough to give a little lateral support) and then slicing through with a razor knife to release the part. Easier than cutting and sanding tabs. But I finally ordered that pressure foot today and am excited to try it out. Of course, being in Canada, I won't receive it for a few more weeks!
Old 08-15-2015, 10:04 AM
dwolbeck dwolbeck is offline
We cut out quite a few of those kind of letters. With my set up I use a 1/4" mortise compression bit. I only make 1/4" deep passes at about 100 ipm. I use lots of tabs and use a flush trim bit with a 3/16" bearing set as high as possible and run around the whole piece, which seems cut down the sanding time a bit. Also after the bit makes the first pass on larger pieces I add additional screws in the centre waste portion to make sure it stays down.
Dennis Wolbeck
SR-44
3.25 HP router
T-slot table
Vcarve software
Old 08-15-2015, 11:09 AM
How big are the pieces you are wanting to cut? Did I miss that part?
