Old 09-07-2015, 09:18 PM
ericw ericw is offline
Default V bit for stainless
Looking for a source for good v bit for fine lettering in stainless steel. I will be doing this on my indexer on the Y axis. lettering depth will be about .015 to .020.
Thanks in advance,
Eric, Owner
Inner Mountain Rifle Stocks
Stinger II
1.7 kw spindle
Indexer
Old 09-07-2015, 09:58 PM
Thanks in advance,
Eric, Owner
Stinger II
1.7 kw spindle
Indexer
Might be better off using a diamond ended engraving drag bit.
US Router tools sells one here
Old 09-08-2015, 07:32 PM
Default v biy for stainless
Thanks Mr Crawford,
I probably should have said that I have tried the Drag. I'm looking for something a little more aggressive in depth.
Old 09-08-2015, 08:28 PM
JeffP JeffP is offline
Try these guys.
http://www.2linc.com/
I've messed around with the Tough Tips for a potential project but they have other options for SS.
Jeff Potts
Cobra 508 ATC
VCarve Pro
Old 09-08-2015, 08:58 PM
I have engraved SS using bits similar to what Jeff linked to on an old Gorton Pantograph. The "Tough Tip" type work well but they leave a fairly wide swath, e.g. fine detail is difficult. The conical type gives finer detail and can be made to work on SS but it's VERY easy to loose the tip. I was thankful I was not paying for them on the project I was working on. There may be other cutter options that I'm unaware of - my pantograph days were back in the early 80's...
Bruce Page
2013 Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
