Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > The CAMhead Locker Room!
Old 12-16-2015, 04:30 PM
CosmosK CosmosK is offline
Default First V carve
I've had VCP for months, but just actually used the v-carve function. Making some plaques for a foundation. One masked one bare, came out pretty good
2014 Stinger II (SR-44)
www.cosmos-industrial.com
>Pen Marking Tools
Old 12-16-2015, 05:54 PM
Very nice. Turned out great.
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
Vectric VCarve Pro 9.0
www.cool-signs.com
Old 12-21-2015, 06:44 PM
Ran 6 of the actual plaques and they all came out great. I wish I had a thickness sander as I had to go back over a couple word to get the depths to look even. Double sided tape help up well.
>Pen Marking Tools
Old 12-21-2015, 06:51 PM
I'm kicking around buying a thickness sander also.
Bob Walters
Lebanon, Ohio
Fast Tool Change
Laser Cross Hair
3.0 kW Spindle
www.cool-signs.com
Last edited by Bob Walters; 12-21-2015 at 07:48 PM. Reason: Change planer to sander oops
Old 12-21-2015, 07:33 PM
Ken Peterson Ken Peterson is offline
CosmosK
Same thing happened to me today. As luck would have it I saw it before removing it from the table. I installed my 1 1/4" surfacing bit and ran a pocket tool path removing .020" then re-ran my tool paths. Came out perfect.
Ken Peterson
Stinger II SR-44
1.7 kw spindle w/speed control
Performance pkg. Plus
Recoil, VCarve Pro
Old 12-21-2015, 08:15 PM
It only happened to a couple corners. The boards, even a small as they are, had a little warp.
I try to not surface the finished face because it will leave tool marks that take a lot of sanding to remove.
When I'm worried, I'll run an indicator over the board before I cut, but in this case they all seemed nice and flat. .008" added depth fixed in on the two words.
>Pen Marking Tools
Old 12-21-2015, 08:18 PM
One thing I learned:
setting the v-carve depth deeper did nothing. If the vbit is wider than the letters, it won't do anything. I had to move my z zero down and rerun that segment of program.
V carve letters were great.
On the dudes, the quality was good but there were some minor issues that I wasn't too crazy about. I can't program in the flat width at the tip of the v-bit and it would do a bunch of extra moves to clean up tiny areas where nothing was left. I suppose I'll figure out workarounds as I get more experience.
>Pen Marking Tools
Old 12-21-2015, 10:26 PM
I bit the bullet a few months back and got a drum sander, great investment !
http://www.camheads.org/showthread.php?t=6503
Only thing negative that jumps out at me here is it looks like Gallant & Few needs a space between them, or more of one.
Old 12-22-2015, 10:44 AM
yeah, I'll probably need to get one eventually.
The spacing was to match how he had them made previously... so I think that's how he wanted them..
>Pen Marking Tools
