Old 06-25-2018, 05:29 PM
Default Source for 3/8 single flute upcut for plastics?
I'm not having much luck in my search. Would like to keep it as budget friendly as possible.
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 06-25-2018, 07:00 PM
eBay is probably your best bet. For example: onsrud
Budget is relative...good tools last longer than cheap ones.
Old 06-25-2018, 07:21 PM
https://www.toolstoday.com/solid-car...keywords=51414
That's a big cutter for plastics, isn't it?
Old 06-25-2018, 08:02 PM
Thanks, I never thought of eBay.
Is polycarbonate considered a "soft" plastic?
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 06-25-2018, 08:11 PM
I don't believe that polycarbonate is considered a "soft" plastic...
Old 06-25-2018, 10:42 PM
I’ve machined a lot of it over the years in a machine shop setting and never thought of it as “soft”. Onsrud lists the 63-776 single flute (for example) to be compatible with “Soft Plastics”. I don’t know what they mean by soft plastics.
I guess the question I should be asking is what cutter is best suited for machining polycarbonate?
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 06-26-2018, 08:03 AM
Soft plastic = stuff like HDPE etc
Hard plastic = polycarbonate
EVERY plastic machines differently. For example, clear acrylic made by Cyro machines differently than smoked clear acrylic by Cyro - since it has more rubber in it. Cast is easier to machine than extruded. Etc...
Polycarbonate is one of the most difficult plastics to machine. It has a tendency to chip, crack and/or melt if you don't get your toolpath right. There is no practical way to drill it on the CNC because it has a tendency to birds nest leaving chips on the bit and then 'spin burnish' the top of the material around the hole. Use a small (1/16" etc) spiral-O flute tool and an inside profile to 'drill' instead.
Pick the right tool for the specific material you are machining: Plastic Routing
FYI - A Single Flute Spiral-O will cut ANY material your CNC router is capable of cutting. Max speed with one flute will be limited to about 90 IPM so keep that in mind. If you need higher throughput, buy a 2 or 3 flute spiral-O finisher, but be conscious of chip clearance...the more flutes, the less clearance you have for evacuating the chip from the kerf. Onsrud has both...and if you are cutting plastics - buy a few of different sizes and keep them in your kit. They last a very long time in plastic...
Old 06-26-2018, 09:12 AM
Provided you NEVER use them to cut anything else.
Old 06-26-2018, 12:21 PM
Great info Brady, thanks.
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
