Old 04-05-2016, 10:25 AM
Peterrock Peterrock is offline
Default Anyone out there cut alumacore?
I have a customer asking me to cut some basic shapes out of alumacore, which is a sheet of coroplast with a thin sheet of aluminum on both sides. Anyone out there have success cutting that stuff?
Peter Piedra
South Florida
Cobra CR-408
5 hp Spindle
V Carve Pro
Old 04-05-2016, 10:50 AM
1601chief 1601chief is offline
Default Toolstoday
Check this out from Toolstoday
https://www.youtube.com/watch?featur...&v=-nhRDKSDews
Andy
Andrew Pierce
Aspire 9.5
Wincnc
2 1/4 hp router
Performance Pkg Basic
Digitizing Probe
KRS Keypad
Old 04-05-2016, 11:06 AM
sgodding sgodding is offline
I cut it for a sign maker on a regular basis. Cuts very nicely with a single 0-flute spiral bit.
Steve Godding
D&S Artistic Woodworking LLC
Old 04-05-2016, 11:59 AM
I'm not talking about aluminum composite material with the solid polyethylene core, I mean the stuff with the corrugated plastic in the center.
Peter Piedra
South Florida
Cobra CR-408
5 hp Spindle
V Carve Pro
Old 04-05-2016, 12:17 PM
Ah, then no. I've never had much luck cutting coroplast with a router bit - tends to leave little uncut tabs. Perhaps someone else knows how it's done.
Steve Godding
Old 04-06-2016, 08:12 PM
WhiskeyBlade WhiskeyBlade is offline
Default Not much help....
We have cut that time to time.... using a waterjet. Would be interesting to see a router do it. I am sure someone can do it.
Stinger I, FTC & Laser
2.25hp Router
INCRA T-Slot
Vcarve Pro and Photo Vcarve
Wired for Indexing Lathe (Someday)
Old 04-07-2016, 05:45 PM
Robert Alexander Robert Alexander is offline
I cut 5mm coroplast using a Southeast tool SPL 210 bit. If you cut at a shallow angle along the flutes of the coroplast you will get plastic stringers but they can be pulled off easily. And I cut in one pass. It's less messy.
Proud owner of a Camaster Cobra 410
Epilog Helix laser engraver
Corel X4 Autosketch 9 Aspire 4
"The economy is not as bad as we are led to believe. Many merchants report this year's going-out-of-business sales are much better than last year."
Old 04-19-2016, 09:55 AM
Default Update....
So I went ahead and cut it the same way I would cut the aluminum composite, signabond material with a 1/4" O flute at 12k rpm and 60 ipm. It cut decently for having a corrugated core. The aluminum skins cut perfect. I had to clean up the core a little with a knife and some sand paper but overall it wasn't so bad. Note, I was only making cuts that ran with the flutes. When you cut against the flutes there will be a lot more to trim/sand. Normally wouldn't be cutting this stuff but the job called for something very light weight and this is the only thing available. If you get right up on it the core looks a bit odd but it's cut cleanly, no way to avoid the way it looks.
Peter Piedra
South Florida
Cobra CR-408
5 hp Spindle
V Carve Pro
Old 04-19-2016, 10:13 AM
Signpronfl Signpronfl is offline
I have used a propane torch to melt those fuzzies away with regular coro. Sometimes it helps. That stuff needs to be blade cut but of course with the exterior aluminum skin that causes problems.
maybe a work flow can be created like below:
What about 3 tool paths?
One to cut top aluminum skin.
Two to cut core using a drag knife
Three to cut bottom aluminum skin
The only problem I see with this is the drag knife may run into the aluminum while cutting.
It would be neat to have a hot knife attachment that could melt the fuzzies after being cut.
I dont know I'm just thinking while typing. I will say that corrugated plastic is just too flexible to cut with a rotating bit.
You could always create your own alumacore. Cut the aluminum skins, than cut the corro using a drag knife then laminate them together after being cut.
Just some thoughts.
Douglas Hancock
Sign Pro of North Florida, Inc.
https://www.facebook.com/SignProFlorida
Stinger 4'x8'
1.7 KW HSD Spindle
Vectric VCarve Pro
Adobe CS4
Old 04-19-2016, 10:28 PM
JeffP JeffP is offline
I find coroplast to be sensitive to the direction of cut- conventional vs climb. I forget which way cuts cleaner but either way it doesn't cut as clean as you like with a router bit.
Jeff Potts
Cobra 508 ATC
VCarve Pro
alumacore, aluminum, coroplast
