Old 01-10-2018, 11:50 AM
cmcanseco cmcanseco is offline
Default G49 & L21/L22 to correct Z Boundary Error
While searching through as many posts as I could find on the subject of intentionally cutting into my spoil board (I'm adding registration holes for 2-sided machining) and getting past the "Error Exceeding Boundary Z-", I found recommendations for using the L21or L22 commands which disable soft limits and other posts recommending G49 which cancels tool lengts offsets. To me, these recommendations just sound so different from each other but seemingly accomplish the same result.
Am I correct in this assumption?
Is one better or safer than the other?
I am not well versed in my G's, L's, and M's and am trying to understand and learn more.
Thanks to anyone willing to explain
Carlos
Cobra 408, 5hp ATC, Recoil, Popup Pins, Remote Handheld Keypad, Hurricane vacuum
Aspire 8, EnRoute 5
Old 01-10-2018, 01:16 PM
Carlos...
Ready for the K.I.S.S. (keep it simple stupid) version?
Type in "T0" (zero not oh)
green and blue boxes should disappear
Manually place the surfacer bit in the ATC spindle
Lower it to the surface of the spoilboard, press "Zero Z" button
Surface Table as needed
IF the spoilboard surfacing file was designed with a numbered tool in it, REMOVE THE TOOL NUMBER from the file
Remove the surfacer manually DO NOT TYPE IN A TOOL NUMBER
type in T# to load your next tool
Old 01-10-2018, 06:48 PM
Pete Cyr Pete Cyr is online now
Gary - he wants to drill holes in the spoil board to register a piece for two sided machining
Pete Cyr
CAMaster Stinger II SR-34 - 1.7KW - FTC
Aspire, WINCNC
Old 01-10-2018, 07:01 PM
Replace "Surface Spoilboard" with "Drill holes in spoilboard" samo samo
